Author Topic: BHP and Torque fiqures bit low?  (Read 3204 times)
Offline ryanr32
« on: 19 April 2009, 12:02 »
me and my mate went to our local RR yestarday (Mikeanics of congleton) just to see what our mk4 1.8T's were running we both have the same engines AGU, mods cone air filter, stage 1 remap mine with r-tech and my friends with revo, plus he's got 110K+ on his clock and i have 90K! so he went on the rollers first to find his running at 188BHP and 230lbft, which we both thought was very good and then when i went on i was only running at 171 BHP @ 5162RPM and 195.7 lbft @ 3836RPM
i checked for boost leaks before(found none) plus had it on VAGCOM (no codes) and had a new MAF last week from VW! i was just abit concerned as of whats going on, was it the remap or somthing else causing my BHP and Torque figures to be so low!
forgot to add the graph is pretty smooth and had no flat spots! :huh:
« Last Edit: 19 April 2009, 12:04 by ryanr32 »
Offline Grand Master Patch
Re: BHP and Torque fiqures bit low?
« Reply #1 on: 19 April 2009, 12:55 »
Have you ever raced your mate side by side? From what i have read R-Tech pride themselves  on having more bhp more of the time.The revo mapped car might have more peak bhp,but i suspect that yours will have a higher average bhp.
Offline boxxer1973
« Reply #2 on: 19 April 2009, 13:02 »
how much longer did it take before you went on? Dont forget as the day gets warmer so you lose power could be down to tyres (pressures or quality)as they might be spinning slightly. do you both use the same fuel? has he got the sps unit if so he may have upped the boost? i personally take RR results with a pinch of salt . mine was 297bhp and 274lbft at jbs then  256bhp and 297lbft torque at TSR yesterday.  as perviously posted have you both ever raced side by side?
Offline ryanr32
« Reply #3 on: 19 April 2009, 14:16 »
we got there at 9am and it wasnt warm! we have had a little race and his mk4 kills mine! something has got to be wrong! we used exactley the same fuel! he got no sps unit! the guy at the rolling road told me he thinks my turbo is knakered!
Offline bobbarley
  • I'm kind of a big deal...
« Reply #4 on: 19 April 2009, 14:18 »
Weird.  I've got an R-Tech re-map, on an AGU engine, with 31k on the clock, and I'm getting 188BHP, and 235lbft.
Offline Rhyso
« Reply #5 on: 19 April 2009, 14:21 »
how does it feel to drive?? does it surge or is the power progressive??
any smoke coming out of the back?
Offline ryanr32
« Reply #6 on: 19 April 2009, 15:20 »
no smoke, just been serviced! feels exactly the same as when i had i remapped but it does serge when the boost kicks in! :huh:
Offline Steve_PD
« Reply #7 on: 19 April 2009, 15:50 »
speak to Nick am sure he'll help you/point you in the right direction :afro:
Offline ryanr32
« Reply #8 on: 19 April 2009, 17:00 »
think i will be giving them a ring tomoz see what the problem is! :smiley:
Offline ryanr32
« Reply #9 on: 19 April 2009, 17:12 »
i have just found a ko3s turbo from a 05 audi tt with 17000k on the clock! is there anything i should be looking for ie part numbers, markings, etc to distinguish it from the ko3!
