Author Topic: TYre Preassures  (Read 1991 times)
Offline sdall30
TYre Preassures
« on: 18 April 2009, 12:36 »
I've got a setu of 15's on the car and the tyre size is 195/50/R15 sho what should the tyre preassuree be , all I can find is that the original 185/60R14's should be 25psi front and rear.
 any help would be appreciated
Offline Lap
Re: TYre Preassures
« Reply #1 on: 18 April 2009, 13:53 »
What model is the car? Had a look in the manual and the only model that has 25 psi front and back is the 1.3 litre.
If it has 195/50 R15's then the recommended pressure is the same again!
Offline sdall30
Re: TYre Preassures
« Reply #2 on: 18 April 2009, 20:07 »
it's an 8v Mk2 GTI
Offline JC
  • Back in the North.
Re: TYre Preassures
« Reply #3 on: 18 April 2009, 20:08 »
erm, dunno,  i change the wheels if a tyre looks flat  :laugh:
Offline gstar-dubworld
  • Here comes the piano man - his a peaceful man..
Re: TYre Preassures
« Reply #4 on: 18 April 2009, 20:47 »
Quality.. :evil:
Re: TYre Preassures
« Reply #5 on: 18 April 2009, 20:50 »
I run 32 psi all the way round (195/45/15 - BBS RM's).. On standard 6 or 6.5" rims I would run 32 up front and between 28~32 at the rear depending on load and if the car is lowered etc.
Offline 16vLeroy
  • Grr bloody car, if everything was as reliable as a
Re: TYre Preassures
« Reply #6 on: 18 April 2009, 21:12 »
Tyre pressure is the same, regardless of tyre size. Tyre pressures corresponds to the kerb weight of the vehicle. Running incorrect tyre pressures, either up or down will increase tyre wear and increase fuel consumption.
See, i've sat through too many tyre manufacturer's training sessions!!!  :wink:
Offline Lap
Re: TYre Preassures
« Reply #7 on: 18 April 2009, 21:43 »
Well according to the manual (again!), if it's an 8V then its 29 at the front and 26 at the back.
Offline DOA
Re: TYre Preassures
« Reply #8 on: 19 April 2009, 09:17 »
The biggest problem here is that each manufacturers tyre will respond better to different pressures and driver preference plays a part here. I find anything below 32PSI on the front on my 195, 50's just makes the steering soggy, bloody heavy at low speed and I personally like the rears to be a bit higher in pressure to balance the car out and sod the wear (they dont wear much on the back whatever pressures you run anyway). Best option for you is to set the rears at one pressure (I run 36-38psi but 28-32 is probably more realistic from a wear and grip point of view) and experiment with the front pressures till you find a setup your happy with, once you have a pressure your happy with on the front, just keep an eye on their wear patterns to make sure they are wearing evenly. The rears arent really doing much so their pressures arent as important to setup unless you want it to slide a bit when your pressing on to help the front end out.
Offline th3_f15t
Re: TYre Preassures
« Reply #9 on: 19 April 2009, 09:27 »
I do 32 psi in the front wheels and about 35 psi in the rear on my mark II GTi 8 valve. Feels fine to drive and haven't noticed any funny or quick tyre wear. Just buy good tyres and shouldn't be a problem.
Moving over to Flickr, sorry for the broken picture links!
