Author Topic: Perished Pipes!!!  (Read 1243 times)
Offline lukesGTI
Perished Pipes!!!
« on: 17 April 2009, 17:59 »
Hello chaps! I have a perished pipe that runs from that black box on top the block what ever that is! to the bottom of the block and is leaking oily air badly. it has perished at the top by the black box next to the throttle body, could this be the cause of a misfire problem that i have? oh where could i get one these breathers online? thanks
Offline golf newbie
Re: Perished Pipes!!!
« Reply #1 on: 17 April 2009, 18:00 »
main dealer about 20-30 max.
or steal one at a scrappy.. :laugh:
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 17 April 2009, 18:01 »
yep dealer only and it will cause a mis fire
Offline ian24driver
« Reply #3 on: 17 April 2009, 23:27 »
dealer wanted £43 off me but was lucky and got one for £3 from scrappy, no oil leaks as yet!!!
« Reply #4 on: 18 April 2009, 10:21 »
If it is the same breather pipe that I had to get it was only £18 from Vw last May.
Offline adyh
« Reply #5 on: 19 April 2009, 12:37 »
I only paid about 18 for mine , although it comes in two parts i only bought the top bit
  • Back in a Mk3...
« Reply #6 on: 19 April 2009, 14:07 »
thats right...mine was the bottom pipe and I was quoted £38  :shocked:
Offline lukesGTI
« Reply #7 on: 26 April 2009, 12:21 »
Cost £15 for the rubber pipe that enters that black box. Replaced but car is still missfiring!
On vag com i have a fault called knock sensor only pops up occasionally and the hall sensor but i have always had these faults but since the car has started misfiring no new fault codes are picked up. Are there any fault codes that do not show up on vag com?
