Author Topic: Meguiars 3 step help  (Read 2644 times)
Offline ravydav
« on: 17 April 2009, 17:55 »
Recently used the 3 step to do my sisters car, came up very nice but too much like hard work for me and going to be doing my own car when home.
Question is;   Car I use any of these with machine polisher or do I have to buy other stuff??
Offline jazzgti777
Re: Meguiars 3 step help
« Reply #1 on: 19 April 2009, 12:24 »
hay im just wondering what is megs three step and what cutting stuff and things would i need?
i have a g220. just not shure what megs three step is or what id need for it lol
Offline Conker
« Reply #2 on: 19 April 2009, 12:52 »
If you don't know what it is, why do you want it then?   :smiley:
See here:  http://www.demon-tweeks.co.uk/products/ProductDetail.asp?cls=ROAD&pcode=MRSA2116
Its mainly hand applied, and basically polishes and protects the paint. Why not save yourself money and time get a bottle of autoglym Super Resin Polish and a tin of Collinite wax. In my opinion, you'll get better results too.
If you want to use your G220, then I would definitely opt for a mild machine based polish (to start with) like http://www.cleanyourcar.co.uk/polishing/polish/meguiars-205-ultra-finishing-polish/prod_564.html
« Last Edit: 19 April 2009, 12:55 by Conker »
Offline eightyeightmph
« Reply #3 on: 19 April 2009, 18:49 »
The Mequires 3 Step consists of a cleaner, polish & wax.
The cleaner is ideal for prepping the paint after a wash or clay, applied like polish & buffed to a shine. Polish applied as per usual & same with the wax.
Not a bad starter set up & reasonable price, BUT the wax isn't great, it's not the easiest to buff off & doesn't last long, so I'd suggest either a second coat of wax, tech 2.0 or similar or dropping the 3 stage wax althogether.
Alternatively just use a better polish/was combo from the start! :afro:
2016 GOLF GTD
Offline Niro
« Reply #4 on: 20 April 2009, 12:49 »
The Megs 3 step is ideally used by hand, I had the same question when I started machine polishing and was told best to get the polishes that are designed for machine use to gain best results.
I started my polishing collection off with Megs #80 and #83
Hope that helps?
NIRO
98 Golf mrk IV GTi 1.8 20V
94 Rover Mini 1275
Offline Niro
« Reply #5 on: 20 April 2009, 12:54 »
Its a good starting block but if you already have a G220 then I'd opt for the machine polish combo results will be better.
I'd finish off with Megs Mirror Glaze #16, goes on nice and is easy to buff. Beads like a bugger :grin:
NIRO
94 Rover Mini 1275
Offline Shady Pioneer
  • graphic designer.
« Reply #6 on: 21 April 2009, 11:23 »
I use the first 2 steps of Megs, but use the Liquid Wax (Gold Class) instead of the 3rd stage wax. Mind you I find this wax doesn't last too long so 2 coats need applying, just waiting for it to run out so I can get some Collinite 915.  :grin:
