Author Topic: How to do vag com runs  (Read 2436 times)
Offline Voodoo-Music
« on: 17 April 2009, 17:31 »
I needto find out whats going on with the car as you have all read by now the vacuum is reading down along with the boost pressure but the car feels ok apart from the idle problem.
How do i use vag com to take a reading what my car is doing with the maf, pressure etc and what am i looking for, i dont have a registered version of the software by the way
Offline richw911
Re: How to do vag com runs
« Reply #2 on: 17 April 2009, 17:50 »
ah you getting close to being the link master lol
cheers rich
Offline Steve_PD
« Reply #3 on: 17 April 2009, 18:26 »
If you want to log boost (I assume you do after reading about N75 problems) log group "011", MAF is "003"  :wink:
« Reply #4 on: 17 April 2009, 18:39 »
is it 115 to check boost or is that charge control. I need to check boost and vacuum
« Last Edit: 17 April 2009, 18:42 by Voodoo-Music »
Offline Steve_PD
« Reply #5 on: 17 April 2009, 18:48 »
your limited with what you can log with the freeware version, you cant log 115, you can log intake pressure which is 011
Offline Rhyso
« Reply #6 on: 17 April 2009, 21:04 »
AGU you can't log boost i believe due to the lack of a MAP sensor
« Reply #7 on: 20 April 2009, 16:21 »
Got my full version of vag com and tried to read blocks 113 but it said its a invalid block ? why would it do that
Offline Rhyso
« Reply #8 on: 20 April 2009, 16:23 »
its 115 isn't it
unfortunately still no good if its an AGU as you can't log boost
also not all the blocks are used - thing to do is log one and the click through them all until you get to the one you want
« Reply #9 on: 20 April 2009, 18:31 »
i did a run on the charge pressure control and the readings are this, this was a third gear foot to the floor up to the redline
Monday   20   April   2009   18:03:28
06A 906 018 CG      1.8L R4/5VT MOTR HS D02
   Group A:   '025            Group B:    Not Running
      Spec. load   Load correc.   Actual load   Valve cycle
   TIME   3-8 m/s   0-8 m/s   0.5-8 m/s   0-99%   TIME
Marker   STAMP    ms    ms    ms    %   STAMP
   0   5.95   5.75   5.85   28.9
   0.38   6.1   5.9   5.9   32
   0.77   6.15   6.05   6   34
   1.14   6.05   6.1   6   34.8
   1.52   5.75   5.85   5.7   29.3
   1.89   8.2   6.1   6   69.9
   2.27   9.4   8.95   8.75   77.7
   2.66   9.25   9.25   8.7   79.7
   3.02   9.15   9.2   8.85   80.9
   3.41   9.05   9.05   9   81.6
   3.78   8.95   8.95   9   82.4
   4.14   8.8   8.85   8.85   82
   4.53   8.75   8.75   8.7   80.9
   4.91   8.65   8.65   8.65   84
   5.28   8.5   8.55   8.6   83.2
   5.66   8.45   8.45   8.5   82.4
   6.05   8.35   8.35   8.3   82.4
   6.41   8.25   8.25   8.3   81.3
   6.8   8.25   8.2   8.2   82.4
   7.18   8.15   8.15   8.2   82.4
   7.57   8.1   8.1   8.15   81.3
   7.93   8   8   8.1   80.5
   8.3   7.95   7.95   7.95   79.7
   8.69   7.85   7.85   7.95   78.5
   9.07   7.75   7.75   7.8   77.3
   9.47   7.65   7.65   7.7   76.2
   9.84   7.6   7.55   7.55   75.8
   10.22   7.55   7.5   7.55   75.4
   10.59   7.45   7.45   7.45   74.6
   10.97   7.35   7.35   7.4   73.8
   11.34   7.3   7.25   7.35   73.4
   11.73   7.2   7.2   7.2   71.9
   12.11   7.15   7.15   7.15   71.1
   12.51   7.1   7.05   7.1   70.3
   12.89   3.05   7.05   1.2   0
   13.28   8.45   7.6   8   77.3
   13.66   8.45   8.35   8.3   79.3
   14.05   7.75   8.15   8.15   68.8
   14.41   3.45   7.25   5.15   0
   14.81   3.6   7.25   1.7   0
   15.18   3.95   7.25   0.75   0
   15.57   4   7.25   0.7   0
   15.93   4.05   7.25   0.7   0
   16.32   4.05   7.25   0.65   0
   16.72   4.1   7.25   0.65   0
   17.08   4.1   7.25   0.65   0
   17.47   4.15   7.25   0.65   0
   17.84   4.15   7.25   0.65   0
   18.22   4.2   7.25   0.65   0
   18.6   4.2   7.25   0.65   0
   18.99   4.25   7.25   0.65   0
   19.36   4.25   7.25   0.65   0
   19.74   4.3   7.25   0.65   0
   20.12   4.3   7.25   0.65   0
   20.51   4.35   7.25   0.65   0
   20.89   4.35   7.25   0.65   0
