Author Topic: N249 bypass  (Read 10537 times)
Offline barry-gti
N249 bypass
« on: 16 April 2009, 21:48 »
Anyone done this?
if so, i understand that you take the hose from the FPR off and put a new piece in. connect a t-piece to the new hose you put on and then connect the original hose to the other another part of the t-piece. then you use the Vaccuum hose from the top of the DV and connect it to the 3rd part of the DV...(if im wrong please correct me)
but what happens to the hole where the vaccuum hose originally goes to? am i missing anything out? all the guides i've seen arent very clear on the whole process
thanks.
Offline (shakey)
  • IS STILL SICK ABOUT CRASHING ME 1.8T AFTER 2 YEARS
Re: N249 bypass
« Reply #1 on: 16 April 2009, 21:51 »
Anyone done this?
thanks.
yes i think you are baz but dont qoute me on that m8.
i will see if i can find a link.
Offline barry-gti
Re: N249 bypass
« Reply #2 on: 16 April 2009, 21:52 »
i've googled it but thats about it lol.
Offline Rhyso
Re: N249 bypass
« Reply #3 on: 16 April 2009, 21:53 »
i think Matt (northeast_gti) has done this mod  :undecided:
Offline barry-gti
Re: N249 bypass
« Reply #4 on: 16 April 2009, 21:53 »
i'll check his project thread
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: N249 bypass
« Reply #5 on: 16 April 2009, 21:57 »
I'd be interested in this too, not for mine but a mate wants his bypassed on his LCR
Offline northeast_gti-t
  • "1.8T AGU"
Re: N249 bypass
« Reply #6 on: 16 April 2009, 21:57 »
lol i did have the n249 by-passed but i started to get a code up on vag-com boost control upper level exeeded so i reverted back to fitting the n249  :wink:
2000 Mkiv GTi 1.8T AGU
Offline barry-gti
Re: N249 bypass
« Reply #7 on: 16 April 2009, 21:58 »
could that cause problems???
  • "1.8T AGU"
Re: N249 bypass
« Reply #8 on: 16 April 2009, 22:06 »
not as such i dont think its just that i got that code and thats the only change i had done the mod was done correctly in how it by-passes just strange  :huh:
Offline BaV
  • 2001 Golf GTI 1.8T AUM
Re: N249 bypass
« Reply #9 on: 16 April 2009, 22:07 »
I finished it all today mate!  I completely changed the piping to and from the N249 Valve and the N112 Valve.
The N249 is now completely removed from the vacuum system but i have left it plugged in so not to bring up a fault code.  The DV i now have running off of vacuum directly from the inlet manifold and i have removed all the excess unnecessary tubbing and reservoirs.
All you need to do this mod is a couple of metres of 3mm Vacuum tubing, 1 T piece (2 if you are running a boost guage like me) some small cable ties and some spare time!
