Poll
What do you normally do?
Place rear tyres to front. New tyres on rear.
13 (52%)
New tyres straight on front, leave the rear untouched.
12 (48%)
Total Members Voted: 22
Author Topic: Where do you fit new tyres???  (Read 6075 times)
Offline ifti
« on: 16 April 2009, 21:02 »
Lets consider the most common scenario - front tyres are wearing down and need replacement soon, while rear tyres seem to have plenty of tread remaining.
Now lets say you purchase 2 new tyres to replace the two worn ones at the front - forget the tyre make for the moment.....
Would you.....
1. Remove the rear tyres (that still have good tread) and put these on the front. Then put the two new tyres on the rear....
OR...
2. Put the new tyres straight on the front to replace the worn ones, and leave the rears as they are...??
Under normal circumstances, i would probably have chosen no.2 above, but Ive just read this article, which was pretty interesting...
http://www.michelin.co.uk/michelinuk/en/car-van-4x4/less-worn-tyres-rear/20070314172074.html
So, what do you usually do in this situation?
Offline JonnyG
Re: Where do you fit new tyres???
« Reply #1 on: 16 April 2009, 21:20 »
I actually rotate mine so that they all wear out together  :tongue: :laugh:
That way you can wait longer and save up for 4 new ones, of a different brand if wanted, with no worries about mixing  :smiley:
Current : Seat Cupra Lux, DSG, Magnetic Grey, Sept 2019
Gone :    Golf Mk 7 R, 5dr DSG, Pure White, March 2017
Gone :    Golf Mk 7 R, 5dr DSG, Tornado Red, March 2015
Gone :    Audi RS3, Daytona Grey, 7sp S-Tronic, Sept 2012
Gone :    Golf R, Rising Blue, 5dr DSG Mar 2010
Gone :    Golf R32, DBP, 5dr, DSG, Nov 2008
Gone :    Golf GTi ED30, Mar 2007
Offline rskardon
« Reply #2 on: 16 April 2009, 21:34 »
I had my new ones on the back for a while (contisport 3's) but swapped them with the front as they are Pirelli P6000 (came with the car, blatantly cheapo's as they were nearly new, i suspect they were put on before the owner sold it) anyway swapped them so the new ones are on the front and she's handling tons better.
I havent notied any issues with handling, feels good,
R
Offline matthewsimone
« Reply #3 on: 16 April 2009, 21:37 »
if your rears really are still in good condition then id be tempted to stick them on the front and wack the new ones on rear that way the rears should last a couple of years and you can stick a new set on the front in 6 months time and have good rubber all round as rears should still be like new tbh only my way of thinking obviously  :smiley:
Offline dan_apps
  • too low for british roads!
« Reply #4 on: 16 April 2009, 22:22 »
put the new ones on the front, fwd & steer cars will handle alot better than having partly worn ones on there!
Offline Hurdy
« Reply #5 on: 16 April 2009, 23:42 »
I've always put the new tyres on the rear. It is the more sensible, safe option and the rear is less likely to snap oversteer with more grip at the back. :smiley:
Seat Leon Cupra Black 290 DSG
Offline R32UK
« Reply #6 on: 17 April 2009, 07:23 »
the rule is to put the better ones on the back and move the rears to the front. Option 1!!
Offline ub7rm
« Reply #7 on: 17 April 2009, 07:23 »
New rubber on the front.  FWD car.  Lions share of the braking, all the power and of course the steering goes through them - why would you wan't anything but the freshest rubber there?  The back wheels are effectively castors to stop the boot being dragged on the floor.
If you drive like a lunatic and your back end often comes out - you need to stop driving like a tit.  In ten years of driving this has never happened to me and I do enjoy the odd B road thrash now and again.  A slightly weaker argument is that with ESP you are much less likely to end up deid these days.
I understand the point fully, and there is some merit to it, but ultimately if you find yourself in the situation that your back end is flicking out (and its not due to ice / diesel spill etc etc) its your driving that needs adjusting - not the tyres!
2020 BMW 128ti
2017 Golf GTD Estate
Offline dan_apps
« Reply #8 on: 17 April 2009, 07:45 »
^^well put! :afro:
Offline R32UK
« Reply #9 on: 17 April 2009, 07:59 »
^^^Thats not actually true.
If you have to slam on for whatever reason would you want your back end loosing grip or the front?? Likewise for any other situation where you have to swerve to avoid something, hit a pot hole or and other obstruction.
The front of the car car be steered where as once the rear has gone it has gone. Your also forgetting about the balance of the car under breaking. :nerd:
