Author Topic: Help req'd!!! 5 speed gear linkage adjustment.  (Read 1906 times)
Offline dan7
  • 85 T25 camper, 90 Mk2 16v, 90 Caddy
« on: 16 April 2009, 19:49 »
What's the easiest way to adjust the gear linkage on a 5 speed? I've loosened the 13mm nut and removed the splined shaft, reinserted in several different positions, but still bad selection. Mostly hard to get 1st & 2nd. Is there a set way or procedure to get this right? Question to.......Rubjohnny!!!  :laugh:
Re: Help req'd!!! 5 speed gear linkage adjustment.
« Reply #1 on: 17 April 2009, 08:36 »
the 'right' way is to take the plastic cover off the rubber boot under the car, ajust it so the gap front & back is the same, and the gap between the reverse lockout finger and tab is 15mm.
the way i do it is put the linkage and stick roughly in the middle, do the pinch bolt up finger tight.  Then go in the car and try all 5 gears.  If you cant get 1st/reverse or 5th put it in 3rd and push the gearstick left or right to fine tune the adjustment, retry the gears. when you get all 5, tighten the pinch bolt :)
Offline dan7
« Reply #2 on: 17 April 2009, 20:04 »
Thanks mate! Knew I'd get an answer from you! I need to get like a Batman sky light, for when I need car help!!!!! Thanks mate!  :wink:
Offline kraM
  • It's not the speed, it's the sudden stops...
« Reply #3 on: 19 April 2009, 22:15 »
Cheers for that, was going to ask too, as I put it into 3rd instead of 5th... bang  :cry:
kraM
It's not the speed... it's the sudden stops...
