Author Topic: Advice required with VAG COM fault Codes  (Read 8240 times)
Offline HÜ84ND
« on: 16 April 2009, 13:12 »
Hi i own a Mk3 Golf GTI 8v (N reg),
I have just run VAG COM (Free Version) on my car and i apparently have the following faults :-
00285 - ABS Wheel Speed Signal #2 (Right Front)
00287 - ABS Wheel Speed Signal #3 (Right Rear)
00625 - Vehicle Speed Signal
01276 - ABS Hydraulic Pump - V64
Can anybody enlighten me as to what action needs to be taken to correct these faults and what the probable causes are ?
Thanks
Offline MK3TDi1996
Re: Advice required with VAG COM fault Codes
« Reply #1 on: 15 July 2009, 08:32 »
hey buddy,
how did you get on? there's a wiki site with listings of all (most) fault codes and meanings...
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #2 on: 08 August 2009, 01:59 »
Having the ABS dash light randomly appear on my vehicle (which is the same as the above) only yesterday, when I ran Vagcom it also brought up one of the same fault codes plus another one.
00287 - ABS Wheel Speed Signal #3 (Right Rear)   Is this a dodgy ABS sensor that needs changing??
00532 - Supply Voltage  (B+)  I haven't a foggiest what this is relation to!!
Can anyone shed any light on what i should do to cure these issues please?
Offline MK3TDi1996
« Reply #3 on: 08 August 2009, 06:13 »
Almost certain it's a dodgy sensor yea, not sure about the other though...
kanemartin101
« Reply #4 on: 13 August 2009, 10:35 »
The other is to do with your airbag mate look on wiki!
« Reply #5 on: 14 August 2009, 18:58 »
Hmm, well at least it doesn't sound serious and my car does seem to be running ok at the moment...
http://wiki.ross-tech.com/index.php/00532#Possible_Causes
