Author Topic: HELP.. JE Pistons for 2.0L 16v Turbo  (Read 1298 times)
Offline Monty_NJD
« on: 27 July 2004, 21:12 »
Where can I get JE Pistons and Con rod's for a 2.0L 16v Turbo VW Golf
2.0L Crank
1800cc Block
82.5mm Bore
Anyone's advise or guidance would be appreciated.
golfvr6
Re:HELP.. JE Pistons for 2.0L 16v Turbo
« Reply #1 on: 27 July 2004, 21:22 »
mk1 (steve) will be able to advise  :)
Offline mk1
« Reply #2 on: 27 July 2004, 22:54 »
16v turbo, excellent.
Have you had the engine bored to get the 82.5, if it is still a 1.8 you could have used G60 pistons. JE's do seem the way to go on a boosted 16vt, only available from the states as far as I know. Check out www.vwvortex.com   there is a forced induction and 16v forum with lots of good advice.
Steve.
