Author Topic: 8v gear box removal  (Read 850 times)
Offline matt2602
8v gear box removal
« on: 15 April 2009, 13:22 »
hey guys can any1 give me a rough guide on how to remove the gearbox from a  mk2 8v 2e engine.  Cheers Matt
Offline Diamond Hell
  • Opinions я Us
Re: 8v gear box removal
« Reply #1 on: 15 April 2009, 14:37 »
Support the engine, remove the driveshafts, disconnect the linkage, reverse light switch and clutch cable, unbolt the bellhousing and just pull it away.
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #2 on: 15 April 2009, 14:48 »
If your on ramps or a jack you might find it easier to take the whole front of the car off, it comes off in 10 mins and does make it a lot easier so slip the box on, if your under a pit its ok to leave it on, its up to you.
Support the engine well,  be prepared for a bit of a fiddle getting the box on,  the diff tends to get in the way a little bit, you might be lucky and find it slips on lovly or you might not,  Either way follow diamond hell's advice basicly,  Other than being a bit of a fiddle sometimes its pretty straight foward!  Good luck  :smiley:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
