Author Topic: VDO Clocks doing some weird things...  (Read 782 times)
Offline russ-vdub
  • Once a Dub, Always a Dub
« on: 15 April 2009, 12:37 »
Flushed my coolant system last night, nothing even near the dash, and now when I turn my headlights on, my rev counter stops working, my full beam led comes on and all the backlights behind the dials go out. Turn the lights off and my revs come back and everything goes back to normal  :huh:
I have checked all the obvious things like connections under the bonnet around the ECU etc but i'm just a little pissed cos i was working in the engine bay, and now my clocks are spinning out  :cry:
Anyone had this before and could possibly help i'd appreciate a lot :)
Thanks
Russ
Re: VDO Clocks doing some weird things...
« Reply #1 on: 15 April 2009, 12:57 »
check zee braided earth cable from back of head/rocker cover to coil bracket bolt
Offline Ben Lessani
« Reply #2 on: 15 April 2009, 13:23 »
Mine was doing the exact same thing on MOT day! When I turned on the headlights, all things on my clocks turned off (revs, fuel, water temp).
I changed a few things, so can't pin it all down exactly for you,
  • The headlight switch plug was slightly loose
  • The H4 connectors on both bulbs had melted through the plastic
  • Part of the main lighting loom was exposed (possible short?)
  • The connectors on the base of the clocks were slightly loose
Mine was doing this intermittently just when driving about, see here. Whacking the dash appeared to make them work again - so I reckon its obviously something loose in the dash.
Since cleaning up the loom in the engine bay and replacing wiring/plugs, I've solved my problem now, fingers crossed.
Offline russ-vdub
« Reply #3 on: 15 April 2009, 15:42 »
Cheers guys. I know that one of the earths has gone in the bay when doing the coolant so will deffo check that first. If not i'll then gone on to check the headlight wiring loom :)
Will report back in a bizzle!
Offline russ-vdub
« Reply #4 on: 15 April 2009, 16:04 »
Awesome! It was the 2 earth cables that had sheared off near the head.
5 minute fix, loves it!
