Author Topic: Need help sourcing parts for my US Golf III  (Read 1088 times)
Offline uta_flyinghigh
  • Fly to live, live to fly
« on: 14 April 2009, 14:04 »
It appears I need parts (both standard and aftermarket) for my US Golf III GL.
It's got the GTI 8V engine but as it's the base car for the US, it seems the suspension setup is more like "normal" Golfs.
I also have no idea if the US Golfs had a GTI brake setup or not.
Can anyone shed some light ?
Thanks
UTA
Offline GOLF_MK
Re: Need help sourcing parts for my US Golf III
« Reply #1 on: 14 April 2009, 15:21 »
Surely the easiest way is to measure the discs?  :huh:
Offline 01664gti
  • mk3 hatch mk3 wagon and mk2 16v
« Reply #2 on: 14 April 2009, 15:38 »
I take its 1 four stud,so i doubt it will.my old vento had the 2.0 8v but smaller discs and calipers
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #3 on: 14 April 2009, 22:23 »
you will probably have the 4 stud vented disks like the TDI, bigger than the non vented i think but not nearly as big as GTI spec.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline boneybradley
  • Back in a Mk3...
« Reply #4 on: 14 April 2009, 22:51 »
search for parts using a 2.0 8v vento/jetta (non gti) as your base.....the spec will be closest to yours  :wink:
« Reply #5 on: 15 April 2009, 09:57 »
Thanks. I have a ton of parts to order from GSF and want to make sure I don't order them wrong.
UTA
