Author Topic: couple little issues  (Read 1855 times)
Offline quattrogal
Re: couple little issues
« Reply #10 on: 16 April 2009, 08:48 »
its strange because with the sensor disconnected the light flashes for about 30 sec and then stays off, with it connected the light flashes all the time.I thought i would try my spare set of clocks , unfortunately the light on those dont work at all.why would it flash and go off with it disconnected .If you disconnect on other cars it flashes all the time , do you think it could be wiring
thx
« Reply #11 on: 16 April 2009, 09:45 »
thats normal, it comes on for a few secs and goes off so you know the light is working. either the new sensor is bust or you have a wiring problem, but if it was a short it should flash all the time rather than just with the sensor connected  :undecided:
try jumping the 2 pins together, does the gauge shoot up to max?
Offline quattrogal
« Reply #12 on: 16 April 2009, 10:16 »
will try it, a friend as a clock but it is the 2 connecter type so i assume that it wouldnt work in my car or i would try it
Offline quattrogal
« Reply #13 on: 16 April 2009, 11:23 »
no the guage didnt move at all , this is bad news
« Reply #14 on: 16 April 2009, 12:32 »
if you have a 90spec car it'll need single plug clocks unfortunatly. does sound like the clocks have gone, bit of a strange problem!  maybe go over the engine with a fine toothed comb looking for any snapped earth cables,there should be at least 1 to rocker/side of head p[lus a chunky earth from the coil mounting bolt
Offline quattrogal
« Reply #15 on: 20 April 2009, 20:50 »
new clocks in , temp guage works and no more flashing light , thanks very much for all the help, quick oil change test the fan and off for mot (hopefully)
« Reply #16 on: 21 April 2009, 11:09 »
cool, fingers crossed it goes through ok :)
Offline P8HJN
« Reply #17 on: 28 April 2009, 13:56 »
.......So how did it go?...did you get to the bottom of the problem??
