Golf mk2
Front 'big' bumper adjustment
Topic: Front 'big' bumper adjustment (Read 1231 times)
jezza16v
14 April 2009, 09:10 »
Hi, is there any way of adjusting the front bumper (big) sideways a bit? Mine seems to be 5mm offset so its tight on the drivers side with a bit of a gap on the pass side. I've slackened off the 4 big bolts but there doesn't seem to be any sideways adjustment. I don't really want to take it off completely if there's nothing on the bumper itself to adjust, its a proper VAG unit btw but not original to this car.
Also found an emergency water supply in both fogs
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Re: Front 'big' bumper adjustment
14 April 2009, 10:13 »
no adjustment, either the car or the bumper is bent
jezza16v
14 April 2009, 10:15 »
Thanks,
rubjonny
10k hero
14 April 2009, 13:14 »
I had the same issue, took bumper off and gave it some hammer love on the bumper arms, did the trick
Agreeable Slick
Global Moderator
Serious forum addict
Unit
14 April 2009, 13:17 »
More than likely a pattern bumper too, as they seem to be larger on one side than the other.
I made this : ->
https://www.golfgtiforum.co.uk/index.php?topic=30416.0
jezza16v
14 April 2009, 17:37 »
VAG stamps all over it? Its 'hammer time' !!!!!!!!
Agreeable Slick
Global Moderator
Unit
Reply #6 on:
14 April 2009, 18:07 »
If it's a pattern cast from an original bumper then yes, it will have the same stamps all over it.
I made this : ->
Golf mk2
