Author Topic: Converting from single wiper back to stock  (Read 2114 times)
Offline frog
« on: 13 April 2009, 20:44 »
My golf has a single wiper conversion that i dont like, cant get used to the wiper blade parked at the 12 o'clock position. How hard would it be to swap back to stock wipers?
I know i will need arms, blades, a wiper motor but looking at the car i will also need the black plastic strip that goes between the windscreen and the bonnet as this was chopped out for the single conversion.
Anything else i will need?
How long will it take and wheres the best place to get the parts?
Offline bratty
Re: Converting from single wiper back to stock
« Reply #1 on: 13 April 2009, 20:46 »
do they all sit at the 12 0 clock position???
could be tempted with it if you wanna do a swap :)
Quote from: Conker on April 28, 2009, 00:32
OMFG. Please tell me you were banging your willy on the keyboard and these were the random words that appeared.
Offline frog
« Reply #2 on: 13 April 2009, 20:54 »
I've been told they all sit at 12 o'clock, if i could change the parked position then i might keep but would prefer stock
Offline bratty
« Reply #3 on: 13 April 2009, 20:57 »
let some1 else post but there must be a way of setting where the blade sits, i dont care though got cracks in me windscreen and allsorts so a blade in the middle wont phase me lol!!
id be willing to remove my stock ones my cars sitting around at the mo doing fek all with a broken gearbox :)
jamie16v
« Reply #4 on: 13 April 2009, 21:09 »
to alter the park position the nut that holds the crank mech to the motor needs to be loosened and put in a different position, then the wiper arm put back in position as desired... its trial and error really..
Offline bratty
« Reply #5 on: 13 April 2009, 21:11 »
there ya go ^^^
Offline Mikester
  • Civic Type R
« Reply #6 on: 13 April 2009, 22:20 »
but the motor is different for the single wiper, as it goes both left and right 90degrees? So i you lay it flat, it will try and wipe your bonnet? lol
Offline bratty
« Reply #7 on: 13 April 2009, 22:44 »
ooohhhh contravercy!
Offline Mikester
  • Civic Type R
« Reply #8 on: 13 April 2009, 22:46 »
Im not sure mate, but i thought that the single wiper was mounted at the center, and the motor changed so it goes 90 each way. Unlike a normal wiper.
So surely you need to refit the orignal motors?
Dont hold me too it, but i reckon its more than just undoing the nut and putting it back flat.
Offline bratty
« Reply #9 on: 13 April 2009, 22:48 »
i aint got a scooby im here for the popcorn
