Author Topic: 1.8 16v KR Starting troubles  (Read 1520 times)
Offline Andy25
« on: 13 April 2009, 19:11 »
Hi peeps,
I'm asking on behalf of my bro who has a corrado 16v, basically one day it just wouldn't start so we started eliminating things replacing his coil, ht leads, dizzy cap and rotor arm. It is turning but it just wont fire, we took the king lead off and turned it over and we only got 1 spark when he released the key. We had multimeter on the live for the coil and it was delivering 8 volts to the coil any ideas because we are stumped!!! Also the central locking has now stopped working....... soooo frustrating!!!!!! :angry:
Andy
« Last Edit: 13 April 2009, 19:46 by Andy25 »
Offline H981CVV
Re: 1.8 16v KR Starting troubles
« Reply #1 on: 14 April 2009, 08:37 »
try your ignition control module which is near your ecu, they only last 75000 miles ish. Its a small black unit mounted on a heat sink.
« Reply #2 on: 14 April 2009, 10:13 »
8v is a bit low, check the ign switch and wiring.  what was the voltage at the battery
Offline Andy25
« Reply #3 on: 14 April 2009, 10:26 »
Cheers people i'll get my bro on it, we did check the wiring from the ignition switch and it does seem ok!
Does this have a grey toggle thing on the side???
Offline H981CVV
« Reply #4 on: 14 April 2009, 11:53 »
its on the right side of the car under the scuttle panel next to the ecu
« Reply #5 on: 14 April 2009, 13:16 »
unless its failed in some way to cause a massive voltage drain that wont be the problem, but i suppose its easy enough to swap on another. a quick n dirty test to see if the low voltage to coil is a problem, run a wire from battery direct to 15 side of coil.  if it works you need to figure out why you only have 8v to coil, if it doesnt look elsewhere
Offline Agreeable Slick
  • Unit
« Reply #6 on: 14 April 2009, 13:19 »
get you or your brother to turn it over, and have someone rotating the dizzy. It's more than likely just fallen out of the correct timing position, then you need to drive it carefully to somewhere where they can set it up properly. (rolling road is best)
Offline hartdub
  • MY VW doesn't leak, it marks its spot!
« Reply #7 on: 15 April 2009, 22:34 »
Hey Guys what about his Central locking issue ???
My golf 16v which ive had probs with starting, (earth lead & dead battery) also recently has stopped doing the central locking.
I can hear the pump work, but it's not locking the passenger door or boot ???
any ideas. thanks.....
Offline Andy25
« Reply #8 on: 16 April 2009, 12:57 »
The central locking now fine, it was relay 72!!!
Still not starting though!! he's orgered a new ignition switch so just waiting for it to come now!!
hartdub have you checked your central locking mechanism on the passenger side? because my bro's wasn't even turning the pump over!
Offline hartdub
« Reply #9 on: 29 April 2009, 11:39 »
No I haven't, Ive had the driver dorr card off, and I know thats working ok, Ill have a look. Silly question: It also locks and unlocks the boot right ??? cheers :laugh:
