Author Topic: supersport coilovers  (Read 2757 times)
Offline mk2-16v
« on: 27 July 2004, 10:09 »
whats the verdict?
Blue MK2
Re:supersport coilovers
« Reply #1 on: 27 July 2004, 10:25 »
harsh ride but excellent handling ;)
Offline Alexg40
« Reply #2 on: 27 July 2004, 22:01 »
Does depend how low you go. The lower you get the worse the handling gets. Just gets too stiff.
Blue MK2
« Reply #3 on: 27 July 2004, 23:14 »
i always thought it was the opposite way around...the lower you go, the smoother it gets?
The helper spring gets very tight when its raised so i thought it would mean a harsher ride?
Offline lairy_1
« Reply #4 on: 29 July 2004, 13:20 »
Not on Supersports - they get progressively harder the lower you go. I should know - mine are wound all the way down! 8)
1983 Mk1 G60
1990 Passat VR6
Offline Alexg40
« Reply #5 on: 29 July 2004, 16:50 »
It wouldn't make sense for them to get softer when they are lower, if you reduce the gap between body and wheel you want to be stiffening the dampers to prevent rubbing, when they are up high you've got the room to bounce around, as opposed to when you are low and there is hardly any space for movement.
Heh!!  When Lairy1 says all the way, he means ALL the way!
Offline Dizzie
  • Make friends with your fast
« Reply #6 on: 30 July 2004, 00:48 »
I was thinking about a set of those. I don't want the ride rock hard though when it's -80mm down.
Mk4 Golf 150PD
Offline mk2-16v
« Reply #7 on: 30 July 2004, 13:17 »
cheers for the info, i think il go for a 60mm drop on the supersports then.
Offline Gambit
« Reply #8 on: 30 July 2004, 15:13 »
as long as the wishbones dont drop below the horizontal you'll be fine
once they go below the horizontal your handling is banjo'd
