Author Topic: Where to get a spare key from?  (Read 3015 times)
Offline krhall
« on: 13 April 2009, 14:33 »
I only have one key for my M plated 1994 Golf Cabrio (mk3) and after loosing the only set I have yesterday for an hour or two I best get some sorted.
The one I have has a press button in the middle I think it is for a light which doesn't seem to work.
Is it a special key I need or can I go anywhere to get it done?
Not sure if it has an immobiliser or not. The car is totally original from the factory except for the wheels.
Offline GOLF_MK
Re: Where to get a spare key from?
« Reply #1 on: 13 April 2009, 15:00 »
I have heard that the key cutters call simpsons can normally do them with the immobiliser for £25ish.
I only have 1 key so need to do the same at some point!
Offline krhall
« Reply #2 on: 13 April 2009, 15:05 »
I'm not sure it has an immobiliser? How can you tell?
Offline GOLF_MK
« Reply #3 on: 13 April 2009, 17:45 »
Pass but the key cutters will probably tell you if you go to the right one.
Obviously dealers should be able to help too but probably twice the price!
Offline MK3TDi1996
« Reply #4 on: 13 April 2009, 18:26 »
I own a '96 CL TDI and the key has a small, black rectangular shaped immobilser chip inside, in the bottom corner.
Methinks that if your key is the same, you do indeed have an immobiliser!
adamrob69
« Reply #5 on: 13 April 2009, 18:35 »
most key cutters will do it, £25 seems a bit steep, im sure mine was about half that, but make sure it is a chip key.
« Reply #6 on: 13 April 2009, 18:40 »
If it is a non immob key you can get one cut for a fiver but your looking at around £25 and up for one with an immob chip.
Offline Shady Pioneer
  • graphic designer.
« Reply #7 on: 13 April 2009, 18:44 »
Gonna go an get a second one done up for myself then, will they enclose it in a VW casing too? :P
« Reply #8 on: 13 April 2009, 18:48 »
No mine was just a standard looking key but I only needed it to get into the boot if the alarm went down.
Offline boneybradley
  • Back in a Mk3...
« Reply #9 on: 13 April 2009, 22:54 »
If you want a vw key then vw is the place (with there prices!) but if you dont mind a second std key then simpsons is fine (£20 for mine with code!)
