Author Topic: is it ok to clean the pressure reg valve?  (Read 1133 times)
Offline difficultrogue
« on: 13 April 2009, 11:36 »
Had a few hours to spend on the 8v gti -when cleaning the throttle body I noticed a split in the breather that runs from the reg valve down in to the front of the engine, the reg valve was caked with grease is it safe to clean it out or would you suggest buying a new part? & are these VW main stealer parts or do gsf or others sell these parts?
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: is it ok to clean the pressure reg valve?
« Reply #1 on: 13 April 2009, 13:02 »
It should be fine to clean it!  the plastic pipes tend to split though to be carefull with them.   I would use brake and parts cleaner, it evaporates fast and breaks grease and oil down.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline axewielder
  • 95 dragon 8v
« Reply #2 on: 14 April 2009, 09:50 »
My Front breather pipe is split too but i think they are like £40 from stealers so might be better goin to scrappy, not 100% sure of price but i get rough prices off ETKA which seem to be quite accurate still
I cleaned out the plastic valve on the valve cover too, i took it off first+ sprayed it with brAke cleaner to break up these big lumps of dried out oily greasy crap
Offline mcgoo
« Reply #3 on: 14 April 2009, 20:48 »
Alright mate I bought the previosly mentioned breather pipe from vee-dub and it was only about £17.
Offline ian24driver
« Reply #4 on: 15 April 2009, 06:18 »
VW wanted £42 last month for this breather!!!
Found a mint one at scrappy in Nottm for £3!
and it came attached to the rubber housing on top of the engine.
Podders at Mapperly top had 3 mk3s in the other month, all look ok and full of bits.
« Reply #5 on: 15 April 2009, 09:13 »
I dont fancy paying stealer prices - Anyone know of a decent scrappy near to Grays, Essex
