Author Topic: heated seats don't work  (Read 5577 times)
Offline mikemk4gti
« on: 12 April 2009, 21:29 »
 The heated seats don't work in my golf mk4, I have checked fuse 44 which i think is the one and its ok.
Where do I go from here? what should I be checking next?
Thanks,
Mike.
51 mk4 gti 1.8t AUM | 05 Audi A3 3.2 Quattro S-Line | 01 A3 1.8t Sport | 02 Golf 25th Anni 1.8T | 03 mk4 GTI AUQ | 05 Leon Fr TDI 150 | mk2 golf gti 8v | 01 Audi S3
Back in my old MK4 '01 AUM!
http://uk-mkivs.net/forums/t/400214.aspx
VagCom, VagTacho, MTE, Needles, Key coding, Locked beeps etc availab
Offline Rhyso
Re: heated seats don't work
« Reply #1 on: 12 April 2009, 21:30 »
heated seat element in the seat base normally burns out
grab your multimeter and check there is power going down the loom - if there is then chances are the element is gone
you can buy replacement elements - takes about an hour to fit
Offline Steve_PD
« Reply #2 on: 12 April 2009, 21:32 »
An hour if you've removed the seat base's once or twice  :wink:
Offline andc1
« Reply #3 on: 12 April 2009, 21:34 »
check the fuse, plugs, if not then elements have gone! best of luck on that one!!!!
Offline Rhyso
« Reply #4 on: 12 April 2009, 21:34 »
reckon i get it down to 45 minutes including a tea break  :smug: :grin:
Offline mikemk4gti
« Reply #5 on: 12 April 2009, 21:35 »
i see theres a few plugs under the seats, which one should i be checking?
Offline Rhyso
« Reply #6 on: 12 April 2009, 21:36 »
think heated seats is the green one - yellow is for the airbags
Offline mikemk4gti
« Reply #7 on: 12 April 2009, 21:40 »
ok, do you know what pins and what i should expect to be getting? 12v?
Offline Rhyso
« Reply #8 on: 12 April 2009, 21:42 »
i don't know personally mate - don't have them; just know that they fail! sorry!
Offline mikemk4gti
« Reply #9 on: 12 April 2009, 21:45 »
ok thanks ne way
