Golf mk4
Wazzzer
split cv boot
Topic: split cv boot (Read 1301 times)
nadlad
Building Surveyor MRICS
split cv boot
12 April 2009, 19:02 »
hi just noticed my wheel was covered in a il liek residue front left side, took the wheel off and noticd the rubber cv joint had come off there oile and shyte everywhere behind the wheel... i need to do a nother 100 mile round trip tomorrow woudl it be ok to still drive it as it is am assumign the oile has all leaked out but i guess theres no where open in the mornign to fix it?
<<<Big Build Thread>>>
jonnyturbo
Forum addict
Re: split cv boot
12 April 2009, 19:06 »
could be risky nadlad
Steve_PD
Serious forum addict
Cruising around in a Land Cruiser
Re: split cv boot
Should be ok, mines doing the same
dai-cymru
1989 MK2 16V
Re: split cv boot
12 April 2009, 20:10 »
If you continue to drive it you will end up needing a new CV joint, if the gaitor isnt split take the wheel off and cable tie it on, cv grease flying near the brake disk isnt a good idea for obvious reasons
golfgtidan
Re: split cv boot
12 April 2009, 20:22 »
also outter c.v boots are mot failure if split or leaking grease....
1999 1.8t : Winter Pack : Kamei Mesh Grille : Forge 007p D/V : Carbonio Cold Air Intake : R-tech remap : 18" Toora Alloys : -30mm Eibach Springs : Smoked Side Repeaters : Hella Magic Colours Rear Lights : Hella Black Headlights : "hid" Headlight Conversion : Aero Blades Front & Rear: ECS KVW100 Window Control Module : Milltek resonated cat back
nadlad
Re: split cv boot
12 April 2009, 20:58 »
now then thanks for the responses i tookt he wheel off and the cv isnt split its just slipped off i saw a plastic cable tie holdign it on which is obviously no good so woudl it just be acase fo findign soem cv boot grease filling it up and then using maybe a steel cable tie to hold it on?
andc1
Re: split cv boot
Reply #6 on:
12 April 2009, 21:07 »
yea make sure you use proper cv grease tho, pack it well or the cv joint will seize and a nightmare to change, if you can get away with it use a big jublee clip, mind it doesnt rub on anything tho
AudiA8Quattro
Forum addict
Re: split cv boot
Reply #7 on:
12 April 2009, 21:09 »
Which side has come off? the big or small side?
Golf mk4
Wazzzer
split cv boot
