Author Topic: Remap wantedd  (Read 2256 times)
Offline zeze89
  • 2000 1.8T AUM
Remap wantedd
« on: 12 April 2009, 18:26 »
 :smiley:
its a 2000 model AUM so fare ive got  a panel airfilter, dump valve and a oiettinger twin exhaust..
not sure if its gont the ko3 or ko3s??
im thinkin sbout getting my 1.8t remaped... what bhp figures will i be looking at??
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: Remap wantedd
« Reply #1 on: 12 April 2009, 22:41 »
Hello.
Welcome to the forum m8! :smiley:
Your AUM will be (should be from the factory) using the k03s turbo which can shift a greater volume of air compared to the older k03 turbo. Our spec1 remap should give you figures of around 210bhp/240lbft if your engine is running spot on.  A small boost leak, or a naff maf can eat away at a huge chiunk of the power.
Your filter and exhaust should help the turbo spool up a bit quicker a d give your small amount of extra mid range power. If you looking for more power, you will need to get a sports cat fitted or de-cat which should take our spec1 remap upto around 225+bhp 250+lbft.
When you say dump valve do you mean the blow off type?
Nick
R-Tech Remaps
01455 619854
 01455 617233
Offline zeze89
  • 2000 1.8T AUM
Re: Remap wantedd
« Reply #2 on: 13 April 2009, 12:07 »
hmm i new to the seen so im not to sure with all the dump valve stuff lol but i  do think its a blow off type.. its a non recirculating type..
Offline RTechUK
Re: Remap wantedd
« Reply #3 on: 13 April 2009, 20:46 »
The remap will work to is best when running a recirculating valve. It will stil be ok with the non recirculating valve but you might see the engine fault light pop up every now and then.
Nick
 01455 617233
