Author Topic: Judder when braking from high speeds  (Read 1732 times)
Offline maverick1984
« on: 12 April 2009, 15:51 »
Afternoon,
When i brake throm high speeds (60mph +) i get quite bad steering wheel shake/vibrations/judder.
Will new discs sort this out? or bushes?
The wheels dont shake when just driving normaly so i have rulled out wheel balancing.
Offline Adam
Re: Judder when braking from high speeds
« Reply #1 on: 12 April 2009, 16:07 »
Warped disk, had this on my  :lipsrsealed: Fiesta  :lipsrsealed:
Down Hill From Here.
Offline Mikester
  • Civic Type R
« Reply #2 on: 12 April 2009, 16:36 »
New discs and pads if i was you.
Would also check the wheels for play/ bearings.
Offline GOLF_MK
« Reply #3 on: 12 April 2009, 18:35 »
Mine does this but it's the bottom bearing in the steering column, the column moves up and down if i pull up and down on the steering wheel.  Might be worth checking that but it's more than likely the disc(s)
« Reply #4 on: 12 April 2009, 19:19 »
Are you running standard alloys, if not well worth checking you have spiggot rings fitted.
« Reply #5 on: 13 April 2009, 00:25 »
The car has standard GTI alloys. I have the disc's and pads in the boot so ill change them and let you know. Many thanks for the help guys
