Author Topic: can the 2 rear engine mounts be modded to lower the block?  (Read 2897 times)
Offline paultownsend
as above
got a bargain of a supersprint manifold for mk2 8v, but i have a tall block agg fitted. so it sits 16mm higher
im not too fond of battering the tunnel, so can the 2 rear mounts be safely chopped, butchered to lower the back of the block?
i found a guide on the mkvr6 forum, but the pics have all gone!
Offline Dolly
Re: can the 2 rear engine mounts be modded to lower the block?
« Reply #1 on: 12 April 2009, 13:18 »
depends how much you need? i needed a very small amount on my G60 so fitted a slightly taller and solid front mount, just tilts the engine enough for the 4 branch to clear.
« Reply #2 on: 12 April 2009, 13:40 »
i suppose i wont know until i get it fitted. had a solid mount in before and just didnt get on with it. il be welding a flexi into the manifold
« Reply #3 on: 12 April 2009, 15:30 »
You may get away without changing the mounts, try it and you may find it clears.
« Reply #4 on: 12 April 2009, 15:44 »
to be honest, im using the std manifold with a 1cm spacer and its perfectwe shall see!
i do not want to wrap the manifold, so whats the best way to protect the steering uj boot?
Offline MarkS
« Reply #5 on: 12 April 2009, 15:50 »
Out of interest
Why do you not want to wrap the manifold?
« Reply #6 on: 12 April 2009, 16:22 »
a, cant afford it
b, i cant be arsed  :smiley:
c, iv just heard mixed stories about them cracking when wrapped, holding moisture, mine is mild steel.
i also knew a guy in his mk1, got oil on the wrap, and had a nice bbq under his bonnet!
Offline MarkS
« Reply #7 on: 12 April 2009, 17:10 »
Ahh fair enough!
You're meant to apply it wet anyway so I suppose doing that on non-stainless steel won't end well!
Also you're meant to spray the heat wrap with a protective spray to prevent damage (flames) etc :)
« Reply #8 on: 12 April 2009, 17:17 »
if i were to do it, id want to do it properly. and it seems to cost a small fortune, with ties, wrap, and paint!  as much as i paid for the manifold!
Offline danny_p
« Reply #9 on: 12 April 2009, 17:39 »
dosent cost that much to wrap it,  i would allways wrap a tubular manifold.  ans would never have a stainless one ether.
if you blow a rod out the back  of the motor and get oil everywhere  yes it'll burn but it'll do that anyway  been there done that.
all the VW's have gone bar 1.
