Author Topic: Warning light identification......  (Read 2436 times)
Offline zanderpants
« on: 11 April 2009, 18:24 »
Hi all,
I have a warning light on the dash and wondered if anyone could identify it for me?
I dont have the owners manual so have no idea what this is??
It is a yellow exclamation mark in brackets with a vvvv sort of thing underneath, there is also a button with his on it near the gear stick and next to the ESP button.
Any ideas?
Thanks!
Offline ub7rm
Re: Warning light identification......
« Reply #1 on: 11 April 2009, 19:03 »
Its the Tyre Pressure Warning System - check your tyre pressure.
Mine pinged last night and at first glance I thought it was lying as they tyres looked OK.  After I checked the TP one was at 1.8 bar (the rest were OK at 2.4) and further inspection revealed there was a nail in the offending tyre  :angry:
The button is for resetting the system / calibrating it when you have the set the tyres to the correct pressure.
I was kindov impressed with the system - I thought it was just a bit of a gimmick!
2020 BMW 128ti
2017 Golf GTD Estate
Offline ifti
« Reply #2 on: 11 April 2009, 20:17 »
Is this standard on all GTI's, or was it an option?
My tyres were running at 29psi up until a few days ago when I checked and put them back up to 37!!
Offline DJGTi
« Reply #3 on: 11 April 2009, 20:25 »
It is a standard feature, but I believe that the warning light will only come on if there is a fairly quick drop in pressure, not a gradual loss.
Offline zanderpants
« Reply #4 on: 11 April 2009, 20:48 »
Thanks for the response!! Just glad it isnt anything major!!
So they should be at around 37 psi?
Offline stealthwolf
« Reply #5 on: 11 April 2009, 20:53 »
Once you've inflated them correctly, insert your key into the ignition and activate the electronics but don't start the car. Then press and hold the tyre pressure button for a good few seconds until you hear the bong. This means that they're now set and should warn you if there's a problem.
Offline ifti
« Reply #6 on: 11 April 2009, 20:54 »
It tells you inside your fuel cap - I have the 18" Pescaras, which come out at 2.6bar, or just under 38psi.
Offline ifti
« Reply #7 on: 11 April 2009, 20:55 »
Is the tyre pressure button the one next to the ESP button, labelled 'Set'?
Offline stealthwolf
« Reply #8 on: 11 April 2009, 20:56 »
Yes.
Offline ifti
« Reply #9 on: 11 April 2009, 21:15 »
Cheers mate - you can see how much of the manual Ive bothered reading ;)
Its much more fun learning things on the go! lol
