Author Topic: Key Codes  (Read 885 times)
Offline jezza16v
Key Codes
« on: 11 April 2009, 08:47 »
Hi, I've been wading through the search but can't find a definitive answer to this one.  :undecided:
Is it possible to get a new door/ignition key cut from the VIN code? (91H 8v 160k)
I only have one key, I presume its the original as it fits both doors & ignition and is so worn now you have to jiggle it in the ignition to get it to turn. Not worth cutting a new one off the old one as there's hardly any profile left on it.....doesn't fit in the hatch lock at all though?
Thanks, J
Breaker
Re: Key Codes
« Reply #1 on: 11 April 2009, 09:40 »
I think there is a code on the ignition barrel?
Re: Key Codes
« Reply #2 on: 13 April 2009, 08:59 »
yep, give your dealer a call. this assumes the locks on the car are original though ;)
I took a blank key and my ign key to a locksmith and he knocked me one up in 5 minutes though
Offline jezza16v
Re: Key Codes
« Reply #3 on: 14 April 2009, 08:50 »
Thanks, I'll check the lock no's, no point in cutting off the existing, there's not much left of it and you have to jiggle it to get it to work the ignition  :laugh:. It fits both doors but won't even go in the hatch?? It seems to be a different type of key in there.  :undecided:
Offline jezza16v
Re: Key Codes
« Reply #4 on: 22 April 2009, 21:19 »
A definitive answer to my original question which may be of interest. Guess which is the new key?
Jan 91 8v 160k- The new key was cut from the VIN records. I took a chance on it being original as the old key still fitted both doors and the ignition (with a jiggle) and I couldn't believe this key was not original given the wear. The new key just needed a squirt of WD40 and a little easing and it now works fine all round (except the hatch).
Has anyone got a key more worn than this I wonder?
Offline maxp
  • J reg 8v digi gti
Re: Key Codes
« Reply #5 on: 22 April 2009, 23:16 »
The leather keyring thing looks pretty cool. Is it 'official' VW?
Offline jezza16v
Re: Key Codes
« Reply #6 on: 23 April 2009, 08:56 »
I don't think so, it just has a local Bath service garage no on the back, not even a VW dealer it seems.
