Author Topic: cutting out  (Read 2003 times)
Offline mystic valver
cutting out
« on: 10 April 2009, 21:41 »
car cut out twice today had to get the AA out in the end, only to find out he didn't have a clue either
i was driving down the road then all of a sudden the engine just cut out wouldn't start again for about half an hour just kept turning over but not firing
any ideas anybody?????? :undecided: :cry: :sad: :angry:
mystic blue valver and C70 T5
Offline jay cee
  • always in front
Re: cutting out
« Reply #1 on: 10 April 2009, 21:44 »
bad earth cable?
1997 Golf GTI 8v - Dragon Green
http://www.nwdubs.com
www.rouleur.cc
Offline harlemex
Re: cutting out
« Reply #2 on: 10 April 2009, 21:49 »
fuel pump relay? (b4 someone else says it :evil:)
Re: cutting out
« Reply #3 on: 10 April 2009, 21:50 »
not earth, thats fine, plugs and leads fine too also oil level and coolant level fine it happened once the car had got warm then started once the car had cooled down it seemed
but when the aa chap came he checked everything  couldn't find any faults took a ht lead off to check for spark and the car started fine but wouldn't before he checked for a spark, its really weird
Offline boneybradley
  • Back in a Mk3...
Re: cutting out
« Reply #4 on: 10 April 2009, 21:52 »
i say its a relay issue (fuel or ecu and when it cools down she restarts)
Re: cutting out
« Reply #5 on: 10 April 2009, 21:52 »
nah not that
Re: cutting out
« Reply #6 on: 10 April 2009, 21:53 »
could be ecu relay though
Offline axewielder
  • 95 dragon 8v
Re: cutting out
« Reply #7 on: 11 April 2009, 10:29 »
When it cuts out does the fuel pump relay click a few times?? because thats what mine's doing and sounds like the same issue, let me know how it goes
Offline ace
Re: cutting out
« Reply #8 on: 11 April 2009, 10:51 »
try cleaning your throttle body and all breather pipes. as mentioned before try checking your relays as well.
Re: cutting out
« Reply #9 on: 12 April 2009, 08:48 »
ive been told by mate the mechanic its the ignition module/coil pack so ive ordered 1 from ebay £22 so not to much i guess, how much are the ecu and fuel relays?
