Author Topic: Mk2 digi petrol leak  (Read 2649 times)
Offline Doug Mk2
« on: 26 July 2004, 13:47 »
I have petrol leaking from the 1st injector (the one nearest the drivers side). It only does it when cold.
What can be wrong with it? How can I fix it?
I'm sure someone out there has an answer!
Doug
Offline frankerooney
Re:Mk2 digi petrol leak
« Reply #1 on: 26 July 2004, 13:55 »
Hmm... I'm no expert on digi injectors, but I suppose generally that injectors mostly have some kind of o-ring or seal on them (Kjet ones do anyhow) which could be leaking, and also a fuel line or separate pipe that feeds the fuel. It could be the union at this point.
If it's only when cold, i assume you're talking about at idle - I'd guess the fuel delivery would be higher when the engine is cold to counteract fuel condensation and so the leak is showing up because of more fuel being released - could be that or just that fact that the leak seals itself up when the surrounding area gets warmer. The injector itself might be cracked too..
 ??? sorry that was a bit rubbish
Offline Gambit
« Reply #2 on: 26 July 2004, 13:55 »
replace the seals or buy a new injector, neither are v.expensive
golfvr6
« Reply #3 on: 26 July 2004, 14:56 »
I believe injectors aren't that cheap, shop around.
Offline Gambit
« Reply #4 on: 26 July 2004, 15:30 »
?25 for a new injector from EuroCarParts - though if your replacing one you may aswell do the 4 of them!
Offline mk1
« Reply #5 on: 26 July 2004, 18:09 »
Are you sure it's the injector leaking, very common for the rubber fuel pipes to leak where they go onto the rail. New hose clips usually fixes it.
Steve.
Offline sco3y
« Reply #6 on: 26 July 2004, 19:37 »
i have on order from vw dealers some rubber washer seals for my injectors. price for 4 was ?9.92 in total with the vat.
not that cheep  just for 4 rubber seals.
i just found out i need 8 of them aswell.
euro car parts said they dont do them for the digifant, main dealers only.
golfvr6
« Reply #7 on: 27 July 2004, 10:09 »
Thats a good price, the price for injectors on an Audi 20v is 50 quid each, and that was from Euro car parts.
