Author Topic: mk1 1.6 gti engine  (Read 1847 times)
Offline dan_b998
mk1 1.6 gti engine
« on: 10 April 2009, 16:24 »
hi i have a 1.6 gti engine with a weber single carb on it does anyone know if the gti engine were fitted with an oil cooler as standard
also does anyone know where i can get a fast road camshaft kit for it
and uprated ignition coil dissy plug leads etc
also wouldn't mind gettin hold of a full engine gasket set and samco silicone hoses for the whole engine
if anyone has any easy ways to tune the engine please let me know
cheers
Re: mk1 1.6 gti engine
« Reply #1 on: 11 April 2009, 07:39 »
yes it was, they had an air cooled oil rad mounted on the slam panel and a different oil filter housing with take offs for the oil lines.
not sure about cam, but dont bother with 'uprated' coil, cap leads etc just buy oem quailty bosch/beru items from gsf or avs, more than good enough. Gasket set again from gsf/avs, samcos ebay best bet
Offline dan_b998
« Reply #2 on: 11 April 2009, 16:52 »
i want to go for the uprated coil etc because i was goin to port and polish the head and skim it and hopefully get hold of a weber side draught twin carbs and lighten and balance the crank rods and pistons and put a better cam and valve springs and try and squeeze as much power out of the engine i can without goin down the turbo or supercharger route
if anyone knows where i can get as much tuning parts fr the engine as possible and obviously uprated suspension and brakes but i know where i can get most of the brakes an suspension parts from just need some decent antiroll bars im also goin to get ligthweight panels
also does gsf and avs have websites i can look on
cheers
« Reply #3 on: 13 April 2009, 08:49 »
even so, standard ign parts will be fine. spark, is a spark, is a spark! important thing is it happens at the right time ;)
www.gsfcarparts.com
www.vwspares.co.uk
Offline dan_b998
« Reply #4 on: 13 April 2009, 18:37 »
very tue
cheers ill have a look a the sites later on
