Author Topic: 4 stud to 5 stud help!  (Read 1398 times)
Offline dazdub09
« on: 09 April 2009, 23:02 »
Hi, Ive got a golf gti mk3 8v south african import with 4 stud for some ofdd reason , im in the middle of converting it to 5 stud, i have done the following, stud axle, disks, and have just found out the wishbone is slightly different so i need a set of them of a golf gti 5 stud,is there anything else ?..
thanks
Offline slicksps
  • Web Design and now DIY mechanic for mkIII CL
Re: 4 stud to 5 stud help!
« Reply #1 on: 10 April 2009, 02:37 »
...Wheels...?
(sorry couldn't resist, can't help but a good bump)
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 10 April 2009, 11:06 »
the european gti has thicker anti roll bars,larger wish bones,uprated steering rack, so it depends on how much you want to convert it to euro spec?
« Reply #3 on: 10 April 2009, 11:29 »
you need drive shafts or outer C/V joints at least, plus the arb needs to be swapped too as the drop link attachments are completly different.
You could use passat 5 stud bones that'll allow you to use 5 stud bearing carriers and your old arb (you are fitting full 5 stud bearing carriers right, not just pressng 5 stud hubs to your old bearing carriers?)
you can keep the steering rack though, it'll work just fine.
Offline dazdub09
« Reply #4 on: 10 April 2009, 18:41 »
I have got gti euro spec stud axles disks, and wishbones so far, drive shafts are the same have got euro spec drive shafts to compare ,
thanks
« Reply #5 on: 11 April 2009, 07:39 »
outer c/vs on 5 stud are different as i say, what do you mean by 'stud axles'
Offline dazdub09
« Reply #6 on: 11 April 2009, 07:42 »
stub axles where you mount thr suspension on and caliper with the hub i have gbot all 5 stud euro spec and euro spec drive shafts .. so all i need is wishbones then ?
