Author Topic: lights left on buzzer  (Read 2331 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: lights left on buzzer
« Reply #10 on: 09 April 2009, 17:05 »
The relay its self buzzes, i had one on my desk a few weeks ago i was fiddling with so i decided to take it to bits, there is an electromagnetic coil, a reed thingy that vibrates, and a casing,  the reed vibrates against a section of the case... thus making a BuZZZZZZZZZZZ Noise.  I hooked it up to my power supply.. i entertained my self for hours with the little buzzy part of it i cant se anything else inside that looks like a relay though, just a coil and a reed  :grin: :grin:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline jay cee
  • always in front
« Reply #11 on: 09 April 2009, 17:46 »
time for me to buy a relay then
1997 Golf GTI 8v - Dragon Green
http://www.nwdubs.com
www.rouleur.cc
Offline Paul86S2
« Reply #12 on: 09 April 2009, 17:57 »
Looks like you will need relay marked 36. Should be in position 9. £rd from left on bottom row of fuseboard.
This should be linked to your interior lights - are your interior lights coming on when you open the drivers door? If not check the door switch.
Paul
Offline jay cee
  • always in front
« Reply #13 on: 09 April 2009, 18:16 »
interior lights work fine.
www.rouleur.cc
