Author Topic: lights left on buzzer  (Read 2350 times)
Offline jay cee
  • always in front
« on: 08 April 2009, 23:50 »
when i leave my lights on, I should hear a buzzer noise, yes?
I dont. Could it be that relay is broken?
Thanks
Jon
1997 Golf GTI 8v - Dragon Green
http://www.nwdubs.com
www.rouleur.cc
Offline boneybradley
  • Back in a Mk3...
Re: lights left on buzzer
« Reply #1 on: 08 April 2009, 23:52 »
yep should have a buzzer (relay 36) http://www.golfgtiforum.co.uk/index.php?topic=74087.0 and its a possibility
Offline jay cee
  • always in front
« Reply #2 on: 09 April 2009, 00:02 »
is there anyway of testing it without buying a new relay?
www.rouleur.cc
  • Back in a Mk3...
« Reply #3 on: 09 April 2009, 00:07 »
only way i can think is to plug it into another car....
Offline Len
« Reply #4 on: 09 April 2009, 08:16 »
All relays should be warm when car is hot. So run car until hot then turn off and take out relay. If its warm to touch all round then its fine. If cold its duff!
Now this is going to sound weird but I had a problem with my lights buzzer not working. Then I had problem with H/U not working on the remote circuit and I believe that was a fault at the ignition switch. So I changed H/U wiring to permanent live and hey presto buzzer also worked!
www.sas.org.uk
www.the-ace.org.uk
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #5 on: 09 April 2009, 11:26 »
My buzzer wouldnt work when my side light bulb was out..? Anyway you can apply 12v to the pins and it should buzz, im not sure if it would get warm though would it?  as far as i can tell it is literaly JUST a buzzer inside but i could well be wrong so dont hold me to that.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline bigun
« Reply #6 on: 09 April 2009, 12:01 »
You learn something new every day! I just assumed my missus 8v didn't have one.  :grin: It'd be handy like. Will have to raid a scrappy at weekend then!
Offline 01664gti
  • mk3 hatch mk3 wagon and mk2 16v
« Reply #7 on: 09 April 2009, 12:40 »
My buzzer stopped working when i changed my stereo,but when i put the standard one back in it worked??
go figure lol
I also thought that the buzzer was built into the light switch itself????
Offline jay cee
  • always in front
« Reply #8 on: 09 April 2009, 13:07 »
so this is the next question, is it the relay the buzz's ? or is it the dash area?
the plot thickens.
www.rouleur.cc
Offline 01664gti
« Reply #9 on: 09 April 2009, 13:34 »
If i had one that worked lol i would go and check lol.But out of all the golfs i have not one work  :grin:
