Author Topic: starting to think I have purchased a lemon  (Read 3081 times)
Offline Daston
« on: 08 April 2009, 22:42 »
Fixed the leak from the powersteering bottle tonight and fired her up to make sure all was ok. Distinct tapping sound from top end. Looked at dip stick and the damn thing was showing just below the low marking. Looked under car and nice puddle of oil! Looks like its seeping from the sump and oil filter. The guy must have known about this and cleaned the bottem of the engine prior to me viewing or it must have gone on my way home :( Topped the oil up and off to get a tyre changed tomorrow and then off to visten my mechanic just hope its a gasket and nothing too serious.
Offline Diamond Hell
  • Opinions я Us
Re: starting to think I have purchased a lemon
« Reply #1 on: 08 April 2009, 22:44 »
Where are you?  There's a load of things that could be leaking.
Offline Daston
« Reply #2 on: 08 April 2009, 22:49 »
Down in sunny somerset.
Offline Ben Lessani
« Reply #3 on: 08 April 2009, 22:58 »
If its coming from the oil filter - just make sure its actually tight (you might be that lucky).
As DH says, clean it all up, get the engine running, then get under it.
If its on the oil filter and no higher on the block, its probably the oil cooler - be it loose from the block or damaged.
If the oil is higher up on the block - then its probably the rocker cover, but I wouldn't have thought enough could leak out from there, all the way down the block to form a puddle on the ground, without building up somewhere else first.
If its leaking at the sump, the sump gasket takes about 30 mins to change and will set you back £8, get the MK3 rubber/metal one. It could be the old owner has done an oil change and not replaced the crush washer and its leaking from there - 20p for a new one.
If it was a puddle - I wouldn't drive the car until its sorted.
« Reply #4 on: 08 April 2009, 23:15 »
Whereabouts in Sunny somerset are you.
Offline ReDBull
« Reply #5 on: 08 April 2009, 23:38 »
It's fun owning classic cars wait till your mot. One step forward and all that.
03 210 Seat LCR. Badger5 V2.2TIP, Fordge 007p, Wellycooler, Quaife ATB LSD, Nuespeed ARB's, KW Clubsports, 330mm discs, 3" turbo back de cat and still on the standard map!
My project thread: http://www.golfgtiforum.co.uk/index.php?topic=241116.0
  • Opinions я Us
« Reply #6 on: 08 April 2009, 23:39 »
I'm in North Bristol.  If you need a hand/advice give me a shout on a PM on here.
Golf2s are simple creatures.  Your fault may well be an easy fix.
Offline tyler
« Reply #7 on: 08 April 2009, 23:47 »
hi bud i will take a look if needed as wayne said whereabouts are you? and the chances are you havent bought a lemon but a car thats over 15yrs old  :wink:
corrado 16v lowered,leather,grill,oz route,m3 lights polished engine,
mk1 golf cabby not alot done but in primer
Offline Daston
« Reply #8 on: 09 April 2009, 07:30 »
thanks guys your making me feel a bit more :smiley: already.
I am in Taunton
Well I did get it as a runaround/project. Just didnt think the project side of things would be so soon lol.
Offline JC
  • Back in the North.
« Reply #9 on: 09 April 2009, 07:52 »
o really  :lipsrsealed:
