Author Topic: turbo or supercharger  (Read 1017 times)
Offline mani12354
« on: 08 April 2009, 22:39 »
i got a 2.0 8v gti where can i get a turbo or supercharger for it from?
Offline boneybradley
  • Back in a Mk3...
Re: turbo or supercharger
« Reply #1 on: 08 April 2009, 22:47 »
It's not that easy!! you really have a few options, either fit a supercharger (better than turbo as you don't need quite as much engine internal work!) but you'll need to fabricate several parts yourself (or buy from america!) or fit a 1.8t engine (much easier and all parts are readily avalible!)
both will cost £2000 minimum (more if you want new parts etc!)
Offline danny_p
« Reply #2 on: 08 April 2009, 23:51 »
if you dont have aircon  an eaton goes on quite easy
all the VW's have gone bar 1.
Offline bored_Welsh_lad
« Reply #3 on: 09 April 2009, 13:36 »
it aint as simple as just bolting it on though...
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
jamie16v
« Reply #4 on: 09 April 2009, 14:17 »
you can get it done for less than £2k using stock parts, it wont be as reliable and you wont be able to run as much boost, but it will work. brackets need to be made and the engine management will need to be changed. unless you have big pockets or you are handy and can carry out most of the work yourself then i would leave it alone..
as you have an 8v the best option for you would be an eaton m45 found on bmw mini coppers and some mercs.
megasquirt is one of the cheapest standalone engine management systems and can prove to be very useful and flexible.
