Author Topic: £25 for fuel pump relay?????????WTF.......bought it but still cutting out!!  (Read 3727 times)
Offline axewielder
  • 95 dragon 8v
Re: £25 for fuel pump relay?????????WTF
« Reply #10 on: 08 April 2009, 17:29 »
LOL yeh maybe not :tongue:
Offline Len
« Reply #11 on: 08 April 2009, 21:43 »
Can be easily checked! Just need to fit in car and drive it for a while, or run it stationary until hot. the take out and if warm all round they fine!
www.sas.org.uk
www.the-ace.org.uk
Offline axewielder
  • 95 dragon 8v
« Reply #12 on: 09 April 2009, 09:12 »
Yeah ECU relay gets warm but fuel on stays cold+ car starts cutting out ater bout 10 mins, its also a light grey 'crap cheap' one!
Offline Len
« Reply #13 on: 09 April 2009, 10:39 »
Aha! Its the fuel relay then!
www.sas.org.uk
www.the-ace.org.uk
Offline axewielder
  • 95 dragon 8v
« Reply #14 on: 10 April 2009, 19:33 »
Or not.......Bought new one from VW, nice new clear/white one made in Germany......same problem
Cuts out after bout 10 mins, relay warms up.....fuel pump relay then goes click bout 3 times as it cuts out????
Cleaned TB out so its all shiney, all vac hoses seem fine+ when i disconect them it starts to die.
The small one from inlet manifold to end of fuel rail is unsplit+unclogged but the engine runs fine with or without it??
So now im thinking could still be ECU relay, new fuel relay is also duff, something up with fuel presure regulator?? if that is the thing on the end of the fuel rail that the vac hose joins to. but the relay clicks as cutting out+nothing comes up on vagcom so im still thinking a relay or something like that!!!!!!!
Cheers for all the help + sugestions guys
Joe
Offline 01664gti
  • mk3 hatch mk3 wagon and mk2 16v
hey fella,let me know what number relay you need as i have some from cars i have broken
Offline axewielder
  • 95 dragon 8v
« Reply #16 on: 10 April 2009, 19:38 »
Us idiots?  :huh:
Does sound expensive! Think when I got mine which was nearly 4 years ago it was about £16.
And yes the ECU was £11 inc VAT
Wouldnt buy the ECP ones!
Sorry man just noticed this, wasn't calling u guys idiots, just thought vw were misquoting.
Uve been realy helpful man cheers for the support!!
Joe
Offline axewielder
  • 95 dragon 8v
Cheers for the offer man but have swaped over a few used ones+ am getting fed up so am prepared for the extreme expense of new relays from the stealers lol, will let u know if i change my mind.
Offline axewielder
  • 95 dragon 8v
+ still running abit rough
might just need new dizzy cap+rotor , found deposits on them, presume its the gap widening+causing deposits from the arcing??
Any suggestions welcomed!!
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
Yes that small bit of vac hose does run to the fpr, sure that vac hose controls it so it should have an effect on it if you remove it. Maybe it isn't working properly, try spraying abit of wd40 through it
Oh and vac hoses can look ok to the naked eye but they can suffer small cracks and can callapse when they get hot, i'd swap those 3 main ones for some silicone 3mm id, get that from the bay for a couple of £££'s.
As for relays, i'd stick to the stealers for them.
