Author Topic: rear wiper  (Read 5309 times)
Offline Deefadog
  • Mk2 16V (November 89)
Re:rear wiper
« Reply #10 on: 12 August 2004, 13:01 »
I'll give them all a go :)
Here is the motions:
Starts flat > push stalk (Click) wiper moves to full upright (click) stops.
Full upright (click) wiper moves to 3 inches before flat (click) stops.
3 inches before flat (click) moves to full upright and back 3 inches etc
so it's like moving on a bit each time and finally returns to flat!
Driving me mad, but I'll do all the things a you say :)
cheers
Offline JMallows
Re:rear wiper
« Reply #11 on: 12 August 2004, 13:43 »
Could have something to do with the parking circuit. It uses a different circuit to park it, when the relay switches off, it uses a different 12V to ensure that it parks properly (bit confusing) could be that once the rel;ay clicks off, normally engaging the park circuit, it doesn't engage the parking circvuit, hence it stopping? Son't know if this is the way it works in Golfs, but i know a lot of old cars used to do this, they probably changed it now to something digtal...
A clever person solves a problem. A wise person avoids it.
Offline Ant
Re:rear wiper
« Reply #12 on: 13 August 2004, 09:33 »
From the flat to upright description sounds like you wipers had the lay flat mod done.
Therefore you should check that the bolt on the motor is secure and that the splines are located and not damaged. (The clicking could be the splines moving over each other)
(More info on the layflat mod in case you need it http://www.matey-matey.com/lay_flat_wiper.shtml)
Offline Deefadog
Re: rear wiper
« Reply #13 on: 16 August 2004, 13:07 »
I forgot about that DakoYam, could be it is a bit loose after the mod was done by the previous owner, I'll check it out.
Also jmallows, how do i fin dout if it has a paking ciruit? what wires do i look out for? a pic would be nice :)
And'll clean the salk and all motors when i am there!
Fielder5757
Re: rear wiper
« Reply #14 on: 16 August 2004, 14:12 »
Take out the whiper and rear squirter and plug the holes with rubber grommits, Then stand back and admire your cars clean smooth euro look  ;)
Offline Deefadog
Re: rear wiper
« Reply #15 on: 16 August 2004, 18:27 »
Euro look is nice, but here in south wales a rear wiper is a must espcially in winter :)
Offline JMallows
Re: rear wiper
« Reply #16 on: 16 August 2004, 20:27 »
Sorry, i don't haave a clue! I was reading about it for another car, the golf mightn't have one... Try them things, then i'll try and think of other stuff it you can't get it to work!
Offline DAVE 2227
Re: rear wiper
« Reply #17 on: 18 August 2004, 23:42 »
My mk2 did this also and I changed relay no 72 and that solved the problem.
Offline DubFan
Re: rear wiper
« Reply #18 on: 19 August 2004, 15:56 »
I had a similar problem on my old mk2. The motor would make a noise as usual but the wiper wouldn't do a full movement.
In the end I bought an entire mechanism and motor off ebay (a 10 quid bargain) and went through replacing bit by bit till I got it working properly.
Basically the problem turned out to be the driveshaft that goes through the boot lid had got really well stuck, which had in turn worn out the motor a bit. Replacing those two bits cured it.
Offline jazzygm
Re: rear wiper
« Reply #19 on: 19 August 2004, 16:15 »
does your rear wiper turn off? mine stays on scraping away until I turn off the engine!  ???
