Author Topic: Mk3 stereo help  (Read 3362 times)
Offline Len
Re: Mk3 stereo help
« Reply #10 on: 08 April 2009, 13:09 »
I had a problem when changing H/U's and was with the remote wire from ignition.
Solution was to wire it up to permanent live.
No idea if this will solve your problem though!
www.sas.org.uk
www.the-ace.org.uk
Offline IanMK3
Re: Mk3 stereo help
« Reply #11 on: 08 April 2009, 19:45 »
just noticed something, when i turn the key the to the first or second click, the HU comes on,but once i get round to the third click, nothing :S
Offline Len
Re: Mk3 stereo help
« Reply #12 on: 08 April 2009, 21:41 »
Thats exactly what I had! Permanent live for you then!
www.sas.org.uk
www.the-ace.org.uk
Offline IanMK3
Re: Mk3 stereo help
« Reply #13 on: 08 April 2009, 22:20 »
hmm isnt that a pain tho, if you forget to turn the stereo off?
Offline dubbinmk3
  • ITS A VAG THING .......YOU WOULDNT UNDERSTAND
Re: Mk3 stereo help
« Reply #14 on: 11 April 2009, 20:09 »
just take the front off the radio eachtime!, you can either tap the red and yellow in together wich will as has been said keep it on untill turned off or the other thing you could do is switch ure ignition on and off and see what works or doesent work with ure ignition off ie: heater controlls, multimeet the wires behind the heater controls and see wich one looses power when the ignition gets switched off,
then tap into that wire and run it up to the ignition live on ure radio...........it will then switch as normal! :smiley:
hope this helps
luke@awesome audio!
*ITS A VAG THING......YOU WOULDNT UNDERSTAND*
