Author Topic: 16v Cutting Out!! – ARRR  (Read 1325 times)
Offline CraigDavid
« on: 06 April 2009, 22:00 »
After About 5-10mins Golf Cuts Out Then Restarts 2-3mins . . Then Cycle Repeats Over And Over And Over!!
Replaced:-
Crank Sensor
Coolant Sensor
Distributor
Rotor-Arm
Distributor Cap
Coil Pack
King Leads
Plug Leads
Plugs
Relay 15 Engine Control Unit
Relay 24 Fuel Pump
Fuel Filter
Cambelt
Anyone Had This Problem?? Any Help Would Be Much Appreciated!!
Thanks
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
Re: 16v Cutting Out!! – ARRR
« Reply #1 on: 06 April 2009, 22:27 »
You replaced all that but have you scanned for any faults..? and i thought ecu and fuel pump relays were numbered 30 and 167!
Offline CraigDavid
« Reply #2 on: 06 April 2009, 22:30 »
ECU Scanned And No Faults Where Shown!!
Offline DazVR6
« Reply #3 on: 06 April 2009, 22:38 »
Ok well when i changed them on my old 16v they had 30 and 167 printed on them...i'd just double check them.
Have you cleaned your throttle body out..? also hows the condition of you vac hoses, especially the one from your throttle body to ecu..?
Offline DubSociety
« Reply #4 on: 07 April 2009, 07:01 »
When I had that problem in the 2nd month of owning my car, I replaced the crank sensor amongst the stuff youve already replaced, but that was the problem on my car ...
I ALSO REPLACED & RECODED THE ECU so I dunno? last resort maybe? as its pretty expensive (cost me about £50 for a replacement ECU and another £40-£50 for re-coding at VW).
Offline Len
« Reply #5 on: 07 April 2009, 08:32 »
Those are their position numbers, if you look on the actual relays you should see the 30 and 167 numbers!  :wink:
You could try an ECU reset by disconnecting the battery completely for 15 mins.
www.sas.org.uk
www.the-ace.org.uk
« Reply #6 on: 07 April 2009, 09:53 »
have you scanned the immobilisor as well?
when it cuts out do all the dash lights flash/light up like they do when you have the ignition on, or does it go dead? Does the car bump start if you lift the clutch, is it cutting out when coming to a stop or when driving?
