Author Topic: knocking from back brakes  (Read 1115 times)
Offline rifleman
« on: 06 April 2009, 17:55 »
hi.i am getting a knock from the o/s/r brake that goes when i apply the brakes...
any ideas would be of great help as this is my first golf and not had much experience with them.cheers
Offline Khare
  • The bear that khares
Re: knocking from back brakes
« Reply #1 on: 06 April 2009, 18:00 »
how about removing the rear wheel and having a look THEN reporting what you find?
Offline rifleman
« Reply #2 on: 06 April 2009, 19:22 »
ever thought i have????  thought i would see on here if there was any common problems not get a cocky reply :tongue:
Offline MrBounce
  • Bora TDi 130 Highline - usually filthy.
« Reply #3 on: 06 April 2009, 20:38 »
Golf GTi Forum - help and sarcasm since 02...
Seriously though, I'd take a look at the pads first - it's possible that the friction material may have broken loose? Also check your wheel bearings, shocks and possibly the springs as applying the brakes transfers the weight towards the front - the spring might not be sitting right or could be broken.
Keeping schtum. Mostly.
Offline Khare
« Reply #4 on: 06 April 2009, 20:38 »
if you're getting a knock then id suggest maybe loose caliper or brake pads.
« Reply #5 on: 06 April 2009, 23:06 »
Sounds like a pad moving, from memory they have spring retaining clips fitted maybe one of those has broken or failed.
Offline rifleman
« Reply #6 on: 07 April 2009, 08:09 »
cheers guys will be whipping brakes apart today and going to put new pads in.hopefully should be ok.if not just turn music up :laugh:
Offline Len
« Reply #7 on: 07 April 2009, 08:26 »
Get it checked properly mate! If you are not competant yourself then get a garage to look.
Dont mess with brakes etc. most important safety feature on a car!
First thing I would check is that the wheel nuts/bolts are tight!
And yes you will get sarcastic replies if you ask questions first and think later!
www.sas.org.uk
www.the-ace.org.uk
Offline rifleman
« Reply #8 on: 07 April 2009, 17:41 »
funny that......
trained at a vauxhall dealership nearly 19 years ago as an auto technician.only left to join the army a year ago.
this is the first mk3 golf gti i have worked on and just wondered if there were any common faults.so as you can imagine i do know how to do wheel nuts up etc. :wink: :wink:
turns out the pads were moving in the caliper.new pads and all sorted.
« Last Edit: 07 April 2009, 17:45 by Shady Pioneer »
