Author Topic: How to pat dry?  (Read 5333 times)
Offline stealthwolf
How to pat dry?
« on: 05 April 2009, 23:55 »
God knows, this sounds silly but how do you dry the car properly?
I've got some proper drying towels (CG's miracle dryer ones) but I don't think I'm drying the car properly and end up frustrated and wipe the car down - very bad, i know!
The way I've tried is to place the towel, fully unfolded, onto a surface, eg the bonnet. Then I press on top of the towel, very lightly, with my hand. But I find this doesn't remove much water and even after patting the entire towel twice, still has water droplets left over.
I've also tried 'dabbing' a folded towel, turning to a clean side when I move on to a new surface. Picks up a bit more water but still not great.
What am I doing wrong?
Offline kdiz
Re: How to pat dry?
« Reply #1 on: 06 April 2009, 08:59 »
Im no expert here but I have seen videos showing detailers wipe their car down by starting off at one end and placing even pressure with two hands [one on their side of the towl] and slowly moving from one end to the other. Given you do have the good towls it should soak everything up.
Jkctr
Re: How to pat dry?
« Reply #2 on: 07 April 2009, 17:46 »
Mate as long as your car is clean and the towel isnt too old or has dirt in it you will be fine wiping. Swirls and micro scratches are unavoidable.
I just wipe mine (yes i videoed leave me alone  :laugh: )
http://www.youtube.com/watch?v=ThPKSsxRx6o
Theres detailing, then theres anal retentiveness!
Offline Conker
Re: How to pat dry?
« Reply #3 on: 09 April 2009, 19:10 »
I wrap my fist in Bounty kitchen paper (it has to be Bounty) and then punch each panel until its dry.
It also helps if you say "eat it, sucker" a lot while you beat the sh!t out of the panels.
I then wet sand the blood stains off with 0001 steel wool.
Offline dan_apps
  • too low for british roads!
Re: How to pat dry?
« Reply #4 on: 09 April 2009, 20:11 »
:laugh:
Offline gibby
Re: How to pat dry?
« Reply #5 on: 10 April 2009, 00:05 »
Dry it with one of these, well worth the money. http://www.elitecarcare.co.uk/eurowxlarge-waffle-weave-microfibre-drying-towel-26-x36-.php Just bought one myself and I can't believe how quick and easy you can dry the car.
......now officially dubless.
Offline stealthwolf
Re: How to pat dry?
« Reply #6 on: 10 April 2009, 00:33 »
I use three of these: http://www.elitecarcare.co.uk/chemical-guys-miracle-dryer-ultra-absorbent-towel-25-x36-.php
But the question is pat-drying technique.
Obviously a weakling. Try punching into sand, fine stones and coarse stones and then try again. Your skin might be tough enough to stop bleeding.
Offline gibby
Re: How to pat dry?
« Reply #7 on: 10 April 2009, 08:35 »
There's a pat drying technique ! :shocked: :grin: I just use my waffle towel and dry the fecker. As long as the towel is clean and all the dirt is washed off the paint then there's nothing to scratch it if you wipe it down.
Watch the first few minutes of this, shows using a waffle towel and also pat drying. Doing the vac bit is taking it a bit too far. http://www.youtube.com/watch?v=BZCi0_55ZDo&feature=related
« Last Edit: 10 April 2009, 08:40 by gibby »
Offline gibby
Re: How to pat dry?
« Reply #8 on: 10 April 2009, 08:41 »
Watch the first few minutes of this, shows using a waffle towel to wipe and also pat drying. Doing the vac bit is taking it a bit too far. http://www.youtube.com/watch?v=BZCi0_55ZDo&feature=related
Offline ...joe
Re: How to pat dry?
« Reply #9 on: 10 April 2009, 09:30 »
BWAAAHAHA HA HA HA HA genious!!! :laugh: :laugh:
but in all seriousness, i just lay the towel on and drag it slowly across. then go back if it doesn't pick it all up.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
