Author Topic: strange juddering.....  (Read 2483 times)
Offline jay cee
  • always in front
« on: 05 April 2009, 22:35 »
when i reach approx. 3000rpm in 3rd, 4th and 5th gear, the car kind of judders (like a kangaroo in the car), until about 3500rpm.
the car idles fine and it doesnt do anything strange in the other gears or the affected gears at other rpm's.
could it be the fuel filter that needs replacing? something tells me that is the problem!?
thanks
Jon
1997 Golf GTI 8v - Dragon Green
http://www.nwdubs.com
www.rouleur.cc
Re: strange juddering.....
« Reply #1 on: 06 April 2009, 08:08 »
need to get it on vag-com really, but worth doing free things like clean throttle body, check vac-hosuing, remove inlet boot and check in all the folds etc.  could be fuel pump or ecu relay
Offline BigDaveC
« Reply #2 on: 06 April 2009, 10:39 »
i'd say those relays too!
Offline Adam
« Reply #3 on: 06 April 2009, 10:41 »
Them bloody relays hit again!
Down Hill From Here.
Offline CraigDavid
« Reply #4 on: 06 April 2009, 21:45 »
Defo Worth Changing Them Relays!! Common Fault On Mk3s . . You Can Get Them From The Main Dealers For Like £10each
Relay 15 Engine Control Unit
Relay 24 Fuel Pump[Petrol] Glow Plug[Diesel]
http://images30.fotki.com/v472/photos/7/783241/5030802/VWGolfGTi16vRelays-vi.jpg
Offline jay cee
  • always in front
« Reply #5 on: 06 April 2009, 23:52 »
it seems to be the air flow meter.
www.rouleur.cc
Offline Len
« Reply #6 on: 07 April 2009, 10:53 »
The numbers on the relays themselves are -
ECU = 30
Fuel = 167
These are what you need to buy from dealer. And its best to get them form a main dealer as they are not expensive!
www.sas.org.uk
www.the-ace.org.uk
Offline boneybradley
  • Back in a Mk3...
« Reply #7 on: 07 April 2009, 11:05 »
vag-com would give you a code......but also try and disconnect the meter and if it runs better then thats another tell tale sign thats at fault
Offline jay cee
  • always in front
« Reply #8 on: 07 April 2009, 12:12 »
a mate of mine unplugged the air flow meter plug, the car was like a rocket!!!!
www.rouleur.cc
  • Back in a Mk3...
« Reply #9 on: 07 April 2009, 12:20 »
well its a new air mass/flow meter you need. these have a stepper motor inside which can become clogged up with crap and unless your very good with cleaning delecate electrics a new one is needed (plus your car will over fuel until this is sorted and could damage the cat!.. even though it's fast the damamge could be costly!)
