The garage
mk3 golf gearbox 1400
Topic: mk3 golf gearbox 1400 (Read 998 times)
Dinky
Guest
05 April 2009, 16:21 »
Hi,
Just wondering if anyone knows if the above mk3 gearbox 1400 would fit onto a mk4 polo?
Thanks
Dinx
Dinky
Guest
Re: mk3 golf gearbox 1400
06 April 2009, 16:28 »
No one?
Dinx
boneybradley
Forum Supporter
Serious forum addict
Back in a Mk3...
06 April 2009, 16:37 »
I'm unsure but i can give you some further box info that may help..
http://boneybradley.webs.com/thegearboxes.htm
If the polo uses an 085 type box then there's no reason it won't fit (seat ibiza's etc use the same code and are interchangable with the golf)
yeha
Just got here
13 May 2009, 14:32 »
There's 2 types fitted to the 1.4 depending on age. The earlier ABD engine has the same gearbox, apart from ratios, as the mk4 Polo. The later AEX engine has an 02x derivative which won't fit.
The garage
