Author Topic: ignition switch  (Read 1583 times)
Offline bitor
ignition switch
« on: 23 July 2004, 15:44 »
can somebody please tell me how I can remove and change the damn ignition switch? I keep hearing things about removing a lockwasher that holds a spring.....but where the hell is that washer and I can't see it???????? Close-up pictures would be greatly appreciated.
Re:ignition switch
« Reply #1 on: 26 July 2004, 08:21 »
If its just the switch you need to change and not the lock barrel (it is seperate part that plugs into the back of the lock barrel)
I think all you need to do is remove the housing from around the steering column (2 screws I think) and you should be able to get to it.  There might be an extra screw holding the switch in place.
Doesn't tanke 5 minutes to check even if I'm wrong ;)
