Author Topic: What have you done to your Golf today?  (Read 1111541 times)
Offline s5haze
Re: What have you done to your Golf today?
« Reply #7000 on: 25 November 2014, 00:08 »
Tinted all lights on car  :cool:
Offline dubsport
  • TDI POWAR!
« Reply #7001 on: 28 November 2014, 16:08 »
Thought about how she is getting on in the workshop having the 1.8T conversion  :evil:
Offline clancy
« Reply #7002 on: 29 November 2014, 22:43 »
Fitted my decat and my bilstein  top mounts front and back
Also sorted my exhaust knocking noise and the fact the car was hunting on tick over
MK3 GTI 16v
Offline clancy
« Reply #7003 on: 30 November 2014, 21:25 »
Well this morning was interesting....
After fitting my new top mounts yesterday I had only done one of the front wheels up finger tight, forgot to do it up properly. So this morning I got 200 yards down the road and two wheels nuts stripped their threads and the others feLloyd put so the wheel fell off...
Luckily I was going very slow so the hub fell into the rim and got jammed rather than completely fall off and trash my front end
Although I now have a big chunk out of the inside of my bbs splits :(
Lesson learnt,  double check your wheels lol
MK3 GTI 16v
Offline oVerboost
« Reply #7004 on: 13 December 2014, 17:16 »
Busy day for the golf today... Fixed a previously bodged repair on the exhaust system where the downpipes meets the first silencer - the sleeve had worked it's way from the downpipe all the way into the silencer (somehow?!) so eventually got that out and then used another sleeve that actually fitted correctly between the two. No blowing exhaust now :)
Also replaced what looked like the original overflow pipe running from the top of the radiator to the header tank as it had dederiorated at the radiator end and was making me loose coolant by venting the steam out.
Then finally fixed my power steering squeel that it seems most mk2's love to have, the bolt on the adjuster wouldn't budge and the pulley could be turned by hand even with a new belt on so often slipped under heavy load - some persuasion with the trusty magic hammer finally moved the adjuster down to the right position and it's nice and tight now.
Hopefully, that'll be it fixing previous owner's bodged jobs.
Offline Mr_Orange
« Reply #7005 on: 13 December 2014, 20:02 »
Sat in the back for a change and checked out all the rattles and knocks you cant hear from the driver's seat :D
Build thread clicky
Offline MarcIV
  • Mk4 GTI
« Reply #7006 on: 14 December 2014, 19:54 »
Changed depth of my NGKs ;D
Flash Red Mk4 golf 1.8t GTI :)
Offline viperjsy
« Reply #7007 on: 17 December 2014, 15:16 »
changed the expansion tank
and changed my top mounts again for powerflex black series top mounts
and changed the drop links
Offline MarcIV
  • Mk4 GTI
« Reply #7008 on: 18 December 2014, 16:38 »
Installed air induction kit.  :smiley: with no knowledge and on my Sweeney tod :tongue: :grin: :evil:
Offline viperjsy
« Reply #7009 on: 10 January 2015, 02:16 »
put auto lights on my golf mk4 gti agu
