Author Topic: What have you done to your Golf today?  (Read 1113339 times)
Offline Golf_GT_TDI
  • 2015 (65) Golf GTD, 2016 (66) Golf GTI
Re: What have you done to your Golf today?
« Reply #5690 on: 02 June 2012, 13:03 »
Picked up some goodies from TPS yesterday...
Offline Bandit127
« Reply #5691 on: 02 June 2012, 19:12 »
Got the tracking and camber done.
A saga that took from 9:30 this morning until 3:00 this afternoon, 2 new track rod ends and a new CV boot. (The fitter burned the old one with the torch trying to free the track rod, so that was replaced FOC).
In the end they fitted the track rod ends for £5 each. I supplied them from ECP - £10.30 something. All up a saving of £35 on the quote they gave me for those. And a big saving on the 1 1/2 hours it took him to replace the CV boot and track rod ends.
While i was waiting I surfed the stock in Cash Converters and found a Kenwood head unit for £17. Bought and fitted with a bit of mucking about (the right rear speaker wires were cut for some reason). The old, knackered silver monstrosity that came out was binned.
Also met 2 new Golf owners. 1 with a Mk1 pickup that was having a few bits done for the MOT and 1 with a Mk4 25th Anniversary GTi that looked very nice. Both top blokes.
A good day for me and my GTi.
« Last Edit: 02 June 2012, 19:15 by Bandit127 »
Offline bourbon
« Reply #5692 on: 02 June 2012, 21:56 »
Fitted apex lowering springs and shocks looks loads better
Peperami........ It's abit of an animal !!!
Offline Bandit127
« Reply #5693 on: 04 June 2012, 19:05 »
If anyone says replacing the thermostat on an AGG is easy or simple they have ramps... On axle stands it's a pig of a job. Still, a tick in the box of stuff to be done.
The coolant that dropped out was clean but I replaced it anyway so that's good for probably longer than the body will last now.
Also adjusted the rear wheel bearings and that got rid of the slight drone above 60. Still planning to renew them as they weren't that loose but they can go down the priority list now.
« Last Edit: 04 June 2012, 19:12 by Bandit127 »
Gavv8
« Reply #5694 on: 04 June 2012, 20:02 »
Re-blacked all the trim with Simoniz backtoblack gel, been using it for a few months now and i'm quite impressed.
Offline Deano2711
  • 1992 VR6
« Reply #5695 on: 04 June 2012, 20:18 »
Oil and filter change, cleaned plugs and air filter and cleaned throttle body then took her for a spin. Drives loads better and really enjoyed the ride  :cool: :cool:
Offline JC
  • Back in the North.
« Reply #5696 on: 04 June 2012, 20:26 »
risked taking it into a certain workshop on a little island, and got it back out without the engine coming out
Offline Dave_IOW
« Reply #5697 on: 05 June 2012, 00:07 »
Got it to where it needs to be   :smiley:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline Dave_IOW
« Reply #5698 on: 05 June 2012, 00:07 »
Could have been as easy as A,B,.....
Offline JC
« Reply #5699 on: 05 June 2012, 00:09 »
not going to happen,  :kiss:
