Author Topic: What have you done to your Golf today?  (Read 1112410 times)
Offline Mitching
Re: What have you done to your Golf today?
« Reply #3720 on: 17 January 2011, 18:39 »
Jacked it up to see why the O/S rear was knocking, turned out the top mount wasn't tight enough and also the arm had come away from my rear wiper motor so that was knocking a bit.
Offline Toby
  • Car - less
« Reply #3721 on: 17 January 2011, 21:57 »
replased this
now it runs  :cool: with no problems..
Currently down under
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #3722 on: 17 January 2011, 22:01 »
removed 10miles of loom from the mk3 engine  :smiley: have no idea what goes where and what plug is what so this conversion should go well  :grin: :grin: rubjonny to the rescue please  :cool:
Offline Jack3559
« Reply #3723 on: 17 January 2011, 22:04 »
Bought the 3rd set of wheels for it... Hopefully I'll like this set.
Offline SoundillusioN
« Reply #3724 on: 19 January 2011, 00:39 »
Got a gas analyser up her ass to see how bad it was after all these years, 2.5 - 3% CO2 not bad considering when the motor was built it should have been 1.8% few tweaks in order.
Offline swede28
  • <a href="http://www.mybannermaker.com" target="_bl
« Reply #3725 on: 19 January 2011, 16:36 »
raised it 2" so i dont botton out on speed bumps at work and discovered a water leak argggg
Offline Mr_Orange
« Reply #3726 on: 19 January 2011, 16:43 »
Bought some treats!  :grin:
Bilstein B4 dampers (VNE4575 / BNE2917)
H&R Sport springs (29526-2)
Build thread clicky
Offline Seanl
« Reply #3727 on: 19 January 2011, 17:57 »
put in a amplified shark fin aerial, sorted out my dodgy wiring to the high vis break light, and fitted a dodgy dummy alarm led that now makes the head unit flash in time! Serves me right for being a tight ass and not actually getting a proper alarm!!
Offline daz veedub
  • Operation 1.8t bolf
« Reply #3728 on: 19 January 2011, 18:41 »
Offline dubmandave
« Reply #3729 on: 19 January 2011, 19:14 »
Re-attached rear washer pipe and all's working as should  :smiley:
"Old Volkswagens Never Die"
    "They Just Get Lower"
           "And Lower"
              "Lower"
