Author Topic: What have you done to your Golf today?  (Read 1113057 times)
Offline Niebz
Re: What have you done to your Golf today?
« Reply #2520 on: 05 June 2010, 23:04 »
Washed it, shammy leathered, polished it, tee-cut the scratches/bugs, blackner on the trims and wheels, crazy acid stuff on the alloys :D looks sweet now hands burnt from the acid tho :/  :undecided:
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #2521 on: 06 June 2010, 03:11 »
well yesterday actually  :grin: picked up a map sensor from vw and some oem lower grilles kindly given to me :afro:
cleaned and treated the lower grilles removed smic and gave it a good clean out and fitted a new map sensor also gave the air inlet temp sensor a good clean as it was black now its back to its original colour  :laugh: see if this cures my prob  :undecided: oh and hoovered it out and then fitted the oem grilles and went for a quick drive  :evil: today i'll probably wash it
2000 Mkiv GTi 1.8T AGU
Offline MrBounce
  • Bora TDi 130 Highline - usually filthy.
« Reply #2522 on: 06 June 2010, 11:23 »
Finally fixed the rear passenger door which wouldn't open from the inside. Cable had come unclipped. It now works! Woo-hoo!!  :laugh:
Keeping schtum. Mostly.
Offline Neo Badness
  • Feet are for pedals
« Reply #2523 on: 06 June 2010, 11:51 »
Had replaced snapped speedo cable, sorted the not working wipers, blower controls died. Brake Master cylinder died so order up a new one, arrived Sat as supposed to be at my first time trial today (Sun). Fitted new M/c, replaced corroded brake lines topped off fluid. Bleeding the brakes I knackered the bleed nipple and thus the caliper @ 1145pm last night in the rush to get it finished. Now can't go to said trackday/ meet :rolleyes:
Such is life
Offline dom
  • Back in a Mk4
« Reply #2524 on: 06 June 2010, 14:57 »
Started to paint the calipers, then it started raining  :angry:
Offline mcgee9t2
« Reply #2525 on: 06 June 2010, 15:05 »
hooverd the inside out :)
hoover posibly doesent work anymore due to the raid  :rolleyes:
my mats changed colour when i goovered them  :undecided: :grin:
Offline Snoopy
  • Geoff.
« Reply #2526 on: 06 June 2010, 16:20 »
Washed the mk1 and was going to detail it then I was also going to replace the alt power lead as one of them is looking worse for ware but it started to spot on to rain and is now raining properly typical :grin: . I spent the rest of the afternoon under the garage ramp changing a crank sensor on a mates car.
« Last Edit: 06 June 2010, 16:24 by Snoopy »
Current Garage:
35+ years of GTI ownership.
  • "1.8T AGU"
« Reply #2527 on: 06 June 2010, 16:38 »
washed it and went out to get another hosepipe for it as the old ones sh!t  :laugh: and got back and it starts raining
Offline Adam
« Reply #2528 on: 07 June 2010, 01:35 »
Properly washed, polished, waxed, waxed, and re-waxed her :cool:
Down Hill From Here.
Offline johnson6672
« Reply #2529 on: 07 June 2010, 09:37 »
Fitted my new hofle lower bumper vents, now i just need to get the cold air feed pipe for the BMC CDA.
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
