Author Topic: What have you done to your Golf today?  (Read 1113055 times)
Offline Sirminty
  • '96 16v GTI, on the lonely south coast
Re: What have you done to your Golf today?
« Reply #1910 on: 19 February 2010, 18:00 »
Established it was a very good shout not to get a pug 306 as it dissapeared behind me in a cloud of white smoke :evil:
Offline shepgti
« Reply #1911 on: 19 February 2010, 18:22 »
it wasnt a gti6 then else you would have been trailing  :wink:
Offline Logie
« Reply #1912 on: 19 February 2010, 21:34 »
Today found the expansion tank leaking, so changed that. Also the metal rad pipe, got all the pipes out except one which is right next to the oil cooler. With the PAS pipes in the way, its impossible to get to the f**king annoying spring clip!
 Dremel tomorrow! That one will be changed to a stainless steel hose clip with screw :P
Offline patty
« Reply #1913 on: 20 February 2010, 10:15 »
well yesterday ,
fitted a new downpipe/cat gasket and 4 x new exhaust rubbers.....nice easy job we thought   lol
all the cat bolts had to be cut ,seized solid.....as were the exhaust rubber bolts that bolt underneatth to the chassis !!!!!!!!!!
4 bloody hrs.........  but least it's all done now :smiley:
pat
1996 black 5 dr 2.0 gti 16v
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #1914 on: 20 February 2010, 18:45 »
Well gave it a good hoover out and got it washed and dried off properly for a change
also solved how my d/v and N75 valve is close to the S3 strut brace by cutting a small section of pipe off each outlet refitted both and sorted theres now clearance to stop any rubbing of the silicon pipe into the top of the d/v :afro:
2000 Mkiv GTi 1.8T AGU
Offline Mr_Orange
« Reply #1915 on: 21 February 2010, 13:02 »
Replaced entire PCV system up to crankcase breather valve (puck).
Build thread clicky
Offline Micah
« Reply #1916 on: 21 February 2010, 13:04 »
This week;
Fitted front discs and pads, replaced rocker cover gasket, new dizzy cap and rotor, max cleaned the interior, new clutch cable, replaced brake fluid, ripped out old Nokia phone kit, water pump pulley, cat/downpipe gasket, hung up Magic Tree :tongue:
On order;
Scorpion stainless system, Anniversary wheels, mats, window regulator, boot carpet, airbox and rear washer jet!
Phew, will be glad of my holiday this Friday! :laugh:
Offline lfcscott
  • Mk3 gti 2.0 8v
« Reply #1917 on: 21 February 2010, 13:12 »
scraped snow off it  :sad: god i hate the f***ing snow :angry:
Offline Chris-White
  • Manufactured in Germany. Ruined in Britain.
« Reply #1918 on: 21 February 2010, 18:56 »
Stripped rear seats & parcel shelf out, covered exposed metal with boot carpet.
Fitted fire extinguisher
changed headlamp bulb
replaced two fuel lines
Offline Cooper_si
« Reply #1919 on: 21 February 2010, 19:31 »
Yesterday a new heaterbox and mk3 matrix....BIG JOB!!
Today just the airfilter....EASY lol  :grin:
Owned: 88 Polo GT Highly Modded (FBC), 91 Polo G40 Highly Modded (PPP), 90 Mk2 Golf Driver Modified (LWR)
NOW: 92 Mk3 Golf GTI 8v (KDD) no, i dont like the exhaust either lol
