General discussion
What have you done to your Golf today?
181
182
183
184
710
Topic: What have you done to your Golf today? (Read 1111541 times)
shorty0100397
GTI forum regular
Golf TDI 100bhp
Re: What have you done to your Golf today?
Reply #1810 on:
06 February 2010, 15:59 »
eye'd up a new grille on ebay. In the red at the min, awaiting some mular.
Sirminty
'96 16v GTI, on the lonely south coast
Reply #1811 on:
06 February 2010, 16:25 »
Re hung my mk3 doors, ahhh no sagging, finnally sounds like a golf
Dan34
VTEC Powerzzzz
Reply #1812 on:
06 February 2010, 16:34 »
Cleaned it inside & out, also fitted my old head unit, f*cked my hands in the process!
whiter_than_white
Here all the time
Seize the day or die regretting the time you lost!
Reply #1813 on:
06 February 2010, 16:43 »
replaced both rear window regs
i can now leave my car without worrying about the window just 'falling down'
Mr_Orange
MK4 GTi Turbo Exclusive 150 AUM
Reply #1814 on:
06 February 2010, 17:35 »
Fitted the 4th and last new coil pack and revived some poke. Didn't sort lumpy idle though...
Tomorrow I will be mostly fitting a temp sensor, tracing a possible vac leak and giving the old girl a clean.
Build thread
clicky
MrBounce
Bora TDi 130 Highline - usually filthy.
Reply #1815 on:
06 February 2010, 23:16 »
Two bucket wash with and rinsed with my new hosepipe
Keeping schtum. Mostly.
northeast_gti-t
Serious forum addict
"1.8T AGU"
Reply #1816 on:
06 February 2010, 23:55 »
hoovered and washed it also painted the domed locknuts and washers i recieved this morning finally collected my S3 strut brace and drilled and painted the holes out in readiness to fit
and tommorrow i should be getting it finally fitted
2000 Mkiv GTi 1.8T AGU
Mr_Orange
Reply #1817 on:
07 February 2010, 14:16 »
Fitted new coolant temp sensor.
Removed, cleaned and re-aligned throttle body.
Removed and cleaned intake air temp (IAT) sensor.
Fiddled around under intake manifold looking for possible vac leak.
Found one of the SAI hoses was loose at the air box.
Seems to idle a bit better now from cold, though still a little "jumpy".
Thoroughly washed it and then admired all my hard work.
Build thread
clicky
johnson6672
Reply #1818 on:
07 February 2010, 14:30 »
Did nothing to the car its self, but picked up a 1.8 16v engine and gearbox, a Rainbow back seat, 3 front grills and a set of arch for my mk2(s)., Got quite a collection of VAG parts going on in my garage now.
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
northeast_gti-t
"1.8T AGU"
Reply #1819 on:
07 February 2010, 14:31 »
finally got my S3 upper strut brace fitted!! admired it and gave it a polish and took some pics for my build thread
181
182
183
184
710
General discussion
